Go to Post BTW - using any Lavery clue to figure anything out could be equally impossible. - Raul [more]
Unread 14-01-2008, 23:06
Brad Voracek Brad Voracek is offline
.999~=1
FRC #0399 (Eagle Robotics)
Brad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of light
Send a message via AIM to Brad Voracek
Our robot is done!
... conceptually ;P
Here's what will probably end up being our final design for this year, with the chassis and the scissor lift (that's what's under that sheet metal). I know everyone says no scissor lifts, but I think we can do it, and it's one of the more efficient methods we thought of, for what we want to do.
... don't mind the cardboard ball. ;P
Questions?
.999~ (Repeating) is equal to one (1).
Team 399 - Eagle Robotics
Unread 14-01-2008, 23:07
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: Our robot is done!
Looks nice.
How is the ball going to be held onto the platform, and then released?
Unread 14-01-2008, 23:17
hipsterjr's Avatar
hipsterjr hipsterjr is offline
Your bot can score but can it dance
AKA: CJ
FRC #4451 (The Burning Magnetos)
hipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond repute
Send a message via AIM to hipsterjr
Be bold, go for the scissor lift. Actually, this is exactly like the design I proposed during brainstorming. Very nice.
2010 Palmetto Chairmens Winner
2009 Peachtree Finalist Thanks 1319 & 590 "Sure your robot can score, but can it dance?!"
2008 Palmetto Regional Finalist Thanks 343 & 804
2008 Florida Regional Finalist Thanks 179 & 69
2007 Palmetto Regional winners Thanks 1319 & 832
2005 Palmetto Chairmens Winner
Unread 14-01-2008, 23:19
.999~=1
We plan to have a "cradle" on the top of the scissor lift, as you can see that there is a lot of room upwards on our robot. We plan to have this sloped downward towards the front of the robot, and those arms you see in the front will actually travel up with the lift to hold it in, and then when they lower the ball -should- roll right down... this is the hard part to test without a ball. (should be in soon!).
The scissor lift also goes up to about seven and a half feet as is, with each section forming perfect squares, we decided above that things kind of sway a bit much..
Unread 14-01-2008, 23:20
Jaybee1405
Posts: n/a
I'm not positive, but your trackball looks a little deflated to me.
Kidding... Normally I am opposed to scissor jacks, but I like the idea in this particular situation because it should make you much less likely to tip, since the weight of the trackball is focused directly over the robot.
Is the ball guided over the overpass by your manipulator after it is jacked up above the 6' 6" level? It appears that way...
EDIT: Yepp, you explained it while I was posting haha
Unread 14-01-2008, 23:22
.999~=1
Exactly right. =).
Unread 14-01-2008, 23:26
Jaybee1405
Posts: n/a
I like the idea a lot Brad. Compact with low CG when speed is needed; tall and strong when hurdling is needed.
Too bad I've had too many bad dreams about scissor jacks or I would bring up a similar idea with my team (AKA copy you! )
Unread 15-01-2008, 16:49
Enigma's puzzle's Avatar
Enigma's puzzle Enigma's puzzle is offline
Strategery
AKA: Matt Brechting
FRC #2075 (Enigma)
Enigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to behold
how do you get the ball off the overpass?
Unread 15-01-2008, 16:58
i_am_samus's Avatar
i_am_samus i_am_samus is offline
Why? Why not.
AKA: Rida
FRC #2590 (Nemesis)
i_am_samus has a spectacular aura abouti_am_samus has a spectacular aura abouti_am_samus has a spectacular aura about
I think they just want to get the ball once someone knocks it down, or knock it over with the thing in the front, though that could tip the robot over.
We actually thought of that idea, and it was almost final, before we figured it may be too hard. Props for doing such a great job, hope you guys do well!
Unread 15-01-2008, 17:20
vhcook's Avatar
vhcook vhcook is online now
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Neat design . It looks like once you get the cradle together so the ball stays put when you move, you'll be in good shape for hurdling.
Where are you going to put the flag holder?
Unread 15-01-2008, 17:30
edgar_amaro edgar_amaro is offline
FRC #2582 (Pantherbots)
Team Role: Student
edgar_amaro is on a distinguished road
ok !!!! but what if they team u up with robots that are similar to that one...... how would u get the ball off the hurdle .....
nice work though ..
Unread 15-01-2008, 17:36
CraigHickman
Posts: n/a
I like. Especially the kid with the TapouT sweatshirt in the background. Gotta love being Bad for the Sport.
(before people jump on me, it's a slogan from the MMA company. I suggest not looking around their store, as some of their ads are a bit "racy")
Unread 15-01-2008, 17:46
Team Role: Student
OK !!! im a rockie this year !!! and we mounted the 2 motors that came in the KOP ( the ones hocked to the gearboxes ).... ok well my question is ...... ive seen many designs that have 2 motors conneced to one gearbox... how do u do that ???? do we need an extra gear or do we just put it there !!!!!!!!!!!!!!!
Unread 15-01-2008, 17:48
Get the gear that you put on the motor shaft. Put it on the shaft. Now, put the motor in. Tighten it down.
Unread 15-01-2008, 18:13
Joe G.'s Avatar
AKA: Josepher
I believe you need to order extra retaining rings, CIM gears, and keys.
http://www.andymark.biz/am-0145.html
(bottum of page)
pic: 233 robot teaser, yep, theres our robot ; ) ducttapedude Extra Discussion 20 15-02-2007 22:02
pic: This is our robot as of last night. Alot more should get done this week now that things are in place dfukuba Extra Discussion 28 25-01-2007 13:14
pic: 1067's robot (almost done) CD47-Bot Robot Showcase 8 17-02-2004 21:41
IS your robot done? team222badbrad General Forum 21 08-02-2003 18:41
Robot done! archiver 2001 3 24-06-2002 00:23
