Go to Post If you let me borrow your time machine, there are various ways to fix this. But mine is on the fritz. - Greg McKaskle [more]
Unread 14-01-2008, 23:21
Capt. Quirk Capt. Quirk is offline
AKA: Bill Mazzacane
FRC #1704 (Robotic Steelers)
Capt. Quirk will become famous soon enoughCapt. Quirk will become famous soon enough
Why don't I ever see robots that steer like a car
Wouldn't that be an advantage in this competition?
Unread 14-01-2008, 23:23
EricH EricH is online now
Re: Why don't I ever see robots that steer like a car
Teams have toyed with the concept before. 812 (2003) and 1135 have tried. It didn't work too well in one of those cases.
Unread 14-01-2008, 23:26
abeD's Avatar
abeD abeD is offline
FRC #4707 (Mentor FRC#4707 Alumni FRC#710)
abeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to behold
It's definitely been done in the past, but it would probably be under 1% of all robots in the last 8 or so years. I know my team did it in 2003 and had some success.
Penn Class 08
Unread 14-01-2008, 23:34
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Ackermen steering is a definite advantage for smooth turns and probably has speed advantages. It's also nicer on the wheels and carpet. However, it's not terribly useful for precise positioning. Imagine if there was a trackball right beside your car. If you wanted to grab it, you'd have to pull a reasonably complicated two-point turn. Or pull all the way around, etc. A tank drive robot merely has to turn 90 degrees in place.
Unread 14-01-2008, 23:39
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
This is a discussion we've been having for a week now! no resolution in sight, either.
We're working on a car steering type chassis design, as well as playing with the control algorithm for last year's 6wd. It'll be interesting to see how this showdown comes out, we are sort of planning to build the Ackermann design and drive both around and see how they compare.
For those who had trouble with car type robots in the past, what specifically were the problems? Your help would be appreciated!
(and Kevin, it might even be better to make another quick lap and make another attempt at the ball!)
Unread 14-01-2008, 23:47
AKA: Bill Mazzacane
squirrel,
Will your team be competing in Las Vegas Too?
Unread 14-01-2008, 23:50
MrForbes's Avatar
AKA: Jim
We signed up for Phoenix and Los Angeles FRC regionals....no Vegas...although the FTC team wants to go to the Vegas FTC regional. We haven't figured out yet if they are, school might interfere with their fun.
Unread 14-01-2008, 23:57
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
The only plus i see to having the front wheels spin like a car is you keep your motors running at top speed while you turn you never slow down as you turn.
As with a tank steer you have to cut power to half of your drive train in order to turn so potentially you are losing speed. Not much but you are....
Unread 15-01-2008, 00:05
MrForbes's Avatar
AKA: Jim
Yup, and if you design the robot with the CG about 6" off the floor like we are, you should be able to just zip around corners like nobody's business.
Unread 15-01-2008, 00:09
popo308's Avatar
AKA: Brent
Very true if you gear it right nobody will be able to catch you as well
Unread 15-01-2008, 00:47
Racer26 Racer26 is offline
1075 did a very "out there" drive as far as FIRST goes in 2003, our rookie year.
Anyone that was at the Canadian Regional that year (now Greater Toronto Regional, as there are now TWO Canadian Regionals!) would have seen it. I think Delphi E.L.I.T.E (FRC#48) gave us an award for most unique drivetrain.
It functioned a bit like a tricycle, we had two undriven wheels at the back of the robot, and an 8" wide track driven by the two CIMs and two Bosch drill motors they used to give us. Then we swung the whole track unit about a point at the front of it. We used a potentiometer on the pivot to track its location, and our autonomous mode was able to climb the ramp very quickly.
I remember that we had a match against one team whose autonomous mode never left the starting box, but instead extended an arm up and over the plexiglass border to reach the pyramid of boxes. Our drivetrain allowing us to turn at full speed got our whole robot to the boxes before they could get their arm there.
This particular unit was plagued by a problem with our inexperience at building drivetrains. It used a miter gear, but we didnt support it closely enough, and under load they were skipping teeth and shredding the gear. We finished 2nd in the competition, mainly because the gear was so shredded we couldn't even climb the ramp.
Unread 15-01-2008, 01:12
AKA: Bill Mazzacane
I'll come and check out your bot in LA. We recieved our funding too late to be able to compete close to home. So were going to Vegas instead.
Unread 15-01-2008, 08:56
65_Xero_Huskie's Avatar
65_Xero_Huskie 65_Xero_Huskie is offline
One T
AKA: Mat
65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute
What do you mean drive like a car?
Like Frontwheel Drive/Backwheel steering?
Vice versa?
I dont get it. I know many robots have done that.
Min-Max to the Max!
Unread 15-01-2008, 08:59
GaryVoshol's Avatar
Cogito ergo arbitro
Perhaps the reason is that teams that have the capability of designing a car-like steering mechanism also have the ability to go to an even more agile design - swerve or crab drive.
(since 2004)
Unread 15-01-2008, 09:13
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Here are a few images of previous robots with steering mechanisms similar to what have been discussed in this thread:
http://www.firstroboticscanada.org/site/node/410
http://www.firstroboticscanada.org/site/node/367
http://www.firstroboticscanada.org/site/node/325
http://www.firstroboticscanada.org/site/node/323
why I don't like this year's game copperhead47 General Forum 40 09-01-2008 08:32
pic: A sight you don't generally want to see Billfred Extra Discussion 8 05-11-2006 23:23
Why I don't like it when politicians visit the QC... Jeremiah Johnson Chit-Chat 4 18-07-2006 15:03
pic: You don't see this often... RoboMadi Extra Discussion 6 03-05-2006 06:24
Can Dean Kamen, inventor of the Segway see why kids like cinnamon toast crunch? Michael Hill Chit-Chat 4 31-03-2006 14:14
