Go to Post The robot competition is the most obvious, visible, and distilled-media-friendly part of the picture... We shouldn't be surprised that it's all that gets into the news coverage, when that coverage is managed by someone who isn't already well versed in what FIRST is trying to do. - Alan Anderson [more]
Unread 15-01-2008, 00:53
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Sprocket with hub or without?
I was just looking at different sprockets to put on the Toughbox output to change our ratio while still using the Toughbox and KOP wheels/wheel sprockets. I was wondering what kind of difference an FRC team would see between a sprocket with a hub and one without. The ones provided in the KOP have hubs but what advantage do they convey, the force of the key spread over greater area?
Basically my question is, are we going to see a difference between something like McMaster part 2299K314 and 6793K133 in this application?
If you can't tell I'm heading into EE not ME
Unread 15-01-2008, 01:05
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: Sprocket with hub or without?
Generally, hubless sprockets are better for dead axle applications, as they transfer the torque from the sprocket to the wheel by bolts, with the assumption that there are bearings in the wheels for the axle. Since they are "dead-axle", the axles do not spin.
Sprockets with hubs are better for live axle applications, as they use the broached (either keyed or hex) shaft of the axle to transfer the torque. With live axles, the bearings must be in the robot chassis, as the entire axle spins.
Art Dutra IV
世上无难事,只怕有心人.
CraigHickman
Posts: n/a
[Edit: I got beat to it. The above post is totally more informative.]
You're going to have more shaft support on the sprocket with a hub, but at the price of a LOT of weight. We usually machine the hub down till it's gone, and mount the keyed sprocket between two shaft collars. Much lighter, and plenty strong enough for a correctly designed chain system.
Unread 15-01-2008, 01:08
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Isn't machining away the hub of a sprocket with a hub the same as just adding a key to a sprocket without a hub?
Unread 15-01-2008, 01:13
CraigHickman
Posts: n/a
Yes, but where we get our sprockets only sells them with hubs. Takes a bit of time, but is well worth the cost savings for us.
Unread 15-01-2008, 01:14
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
the difference is in how thick the two sprockets are. The hubless sprocket is designed to be attatched to something flat, not just put on a shaft. The hub sprocket is designed to mount to a shaft.
Usually the hub type sprockets are very heavy and the hub portion of it is much larger outside diameter than it needs to be.
Need help with locking on sprocket Shaggy9356 Kit & Additional Hardware 6 18-01-2007 22:25
connect three computers without hub kirov Chit-Chat 9 28-02-2005 18:55
Weigh in with or without battery Joe Clohessy Rules/Strategy 33 21-09-2003 20:31
Render with or without threads SGK 3D Animation and Competition 2 18-02-2003 15:32
wheel hub kit and sprocket archiver 2001 7 23-06-2002 23:27
