Go to Post Mark McLeod, spreadsheet whisperer - PayneTrain [more]
Unread 14-01-2008, 20:26
David Fort David Fort is offline
FRC #1001
David Fort is on a distinguished road
Binding AndyMark Toughbox transmission?
Hi.
We are having trouble with binding in one of our AndyMark Toughbox transmissions supplied with the 2008 KOP.
It looks like once per revolution of one of the big gears, it is very hard to turn by hand, and if run under motor power, makes a hideous noise.
Hard to say for sure, but it looks like the gear might be eccentric.
Anyone else having problems like that?
Thanks,
David Fort
Team 1001
Rockwell Automation
Unread 14-01-2008, 20:28
Stillen Stillen is offline
Stillen is just really niceStillen is just really niceStillen is just really niceStillen is just really niceStillen is just really nice
Send a message via ICQ to Stillen
Re: Binding AndyMark Toughbox transmission?
oooh yes, ours is as well..... one of the gears has a ton of play in it............ we even tested ours with a cordless drill, just stuck the shaft into a drill and spun it up, it binded right up..
Unread 14-01-2008, 22:12
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
We had a tight spot on one of our transmissions. Try to see if there is a burr on the gear that needs to be filed down. Also remember to put grease in them. It makes them a lot quieter.
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
Unread 14-01-2008, 22:20
run the trap!!!
Team Role: Human Player
Likely Problems
1) You assembled it wrong.
2) You tightened the bolts too much.
3) You tightened some of the bolts more than others (Anyone who works on cars knows why this is a problem)
4)There is no problem. Spur gears are just really noise, put some grease on them and hook up the CIM, a little wear will break them in.
I had trouble turning the toughboxes by hand the first time we assembled ours. After we ran them a little bit with some white lithium grease they worked just fine.
-Philip J. Fry
Unread 14-01-2008, 22:21
in between teams
AKA: Luke Van Oort
Are you certain that the little raised parts on the gear faces face the bearings? That is rather important bit that could cause this behavior and is easy to miss.
Team 1219: 2009 - Mentor
Unread 15-01-2008, 00:09
rocknthehawk's Avatar
rocknthehawk rocknthehawk is offline
AKA: Aaron
FRC #1768 (Robo Chiefs)
rocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to behold
does the fact that the boxes aren't square bother anyone else?
Unread 15-01-2008, 00:12
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
What do you mean they're not square?
Unread 15-01-2008, 00:13
comphappy comphappy is offline
AKA: Brennan Ashton
FRC #2605 (A2D_16)
comphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to behold
Send a message via AIM to comphappy
ours ended in the scrap pile within two days, on one of them the hole was not big enough for the bearing, and it had to be reamed out a bit. A really shotty part for an expensive KOP.
Unread 15-01-2008, 00:14
AKA: Aaron
measure each corner. Ours weren't the same. it was cut at a slight angle and just sanded down.
we also had to drill holes in one bigger, and the other didn't even have them.
Unread 15-01-2008, 00:55
CraigHickman
Posts: n/a
You do know the bearings are supposed to be press fitted in? And if it's such a shoddy part, then please post something that YOU have designed and made that costs less, weighs less, and is more reliable then this gearbox. This is a challenge I'm confident cannot be done by most FIRST teams.
[/rant about teams complaining about such an awesome piece of the KOP]
Unread 15-01-2008, 00:58
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
Banebot has a problem with their transmissions. The tolerances are off... Sometimes the motor shaft pushes up against the case of the transmission... I have 4 and two of these have that problem. I put a small washer on all 4 screw between the motors and the transmissions. It backs the motor shaft back just a bit but that's all it needs. This creates a gap around the motor to transmission joint, but I can tape that and the unit runs smoothly. If that's not for you, you can try making a spacer gasket with just thick cardboard.
I've done both and they've worked perfectly. I went to the washer because... I'm Lazy... It's a gift. (If you want to find the most efficient way to do something... put your laziest person on it.)
Hope this helps
Steve
(Some of you sound like you might have a different issue... but look in the transmission and see if you are getting small metal pieces or scratches on the inside of the transmission. either of these is the spacing problem. I've worked with 8 Banebot transmissions and this is the only problem but it's a darned consistent one!)
Unread 15-01-2008, 01:01
CraigHickman
Posts: n/a
Hope this helps
Steve
I don't think we got the Banebots gearboxes in the kit this year... just FYI....
Unread 15-01-2008, 01:08
Oh My mistake... Don't know about the New Andy Mark transmissions, but the older ones... well you just had to hold your mouth right to assemble them... and use a lot of grease.
Steve
Unread 15-01-2008, 01:13
CraigHickman
Posts: n/a
Steve
Yep. The Banebots, once working, were awesome. I'm excited to see how the Toughbox performs on the field. All of our shop tests indicate it to be a very strong system.
Unread 15-01-2008, 01:15
AKA: Brennan Ashton
FRC #2605 (A2D_16)
an 1/8" too small is a little more then press fit. It sounds like some are great, but others just were not done right at all (like the one with no holes). Looks like a good design, but a little more QC could go a long ways. It is not an issue for our team seeing as we are not using them anyway.
Toughbox Assembly mjgard General Forum 39 16-01-2008 19:27
AM Toughbox Model(s) available Ed Sparks CAD 2 08-01-2008 11:15
Second AndyMark transmission query N0s3Nugg3t Technical Discussion 2 05-01-2008 15:29
Programming Servos For AndyMark Transmission de_ Programming 6 30-01-2007 08:52
