Go to Post Unlike robot design, in the clothing world there's no such thing as too much pocketing - Jaci [more]
  #61   Spotlight this post!
Unread 29-12-2007, 01:36
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Re: Problems with IR Board
Originally Posted by Chris_Elston View Post
1501 IR board works great out of the box.
Hmm....I don't quite understand how you are powering your IR board. Is the power coming from one of the IO ports on the Vex controller? The power output is only 5V, so does the IR board still work when the minimum required input voltage is 7V?
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
  #62   Spotlight this post!
Unread 29-12-2007, 12:26
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Vex controllers are quite similar to the FRC RC. The Vcc voltage out on the Analog in and Digital in/out connectors is +5vdc. The Vcc voltage on the PWM connectors is the same voltage as the backup battery on the RC and the main battery on Vex, both being +7.2vdc.
  #63   Spotlight this post!
Unread 29-12-2007, 12:35
sayso_411's Avatar
sayso_411 sayso_411 is offline
10 Years of Sparky!
AKA: Shaav
FRC #0384 (Sparky)
sayso_411 can only hope to improve
Red face Re: Problems with IR Board
Hmmm... thats funny because our IR board worked at first try with a Toshiba TV remote (cant tell but probably something wrong with IR board)
  #64   Spotlight this post!
Unread 29-12-2007, 15:42
Engineering Mentor
Well that's good to know. I can't see exactly where the power is coming from by looking at the picture. It really still looks like they're coming from the Analog/Digital IO ports, but I guess they could be from the motor ports.
Chris_Elston, where are the power leads connected?
  #65   Spotlight this post!
Unread 31-12-2007, 19:20
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
I had the power on the PWM servo power 7.2 volts on the VEX as spec'd, but then I decided to try it on the I/O side as you see in the pictures. There is only 5V on that side of the VEX controller. So the IR board works at 5volts....dog gone it...the cat's out of the bag....I didn't move the wires when I took the picture....
I have logged in feet the signal degrading factor using 5 volts, verses 7.2 volts. It's about 0.37 times factor.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
  #66   Spotlight this post!
Unread 05-01-2008, 21:57
Wendy Holladay's Avatar
Wendy Holladay Wendy Holladay is offline
FRC #1912 (Team Combustion)
Wendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond repute
get a board at all
does anyone know how to get a board, ours got lost, can you buy them, should i call first or ifi?? any help would be get
wendy holladay
mentor team 1912
  #67   Spotlight this post!
Unread 07-01-2008, 02:41
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
Re: get a board at all
wendy holladay
mentor team 1912
I'm not sure. I'd like to get a backup one as well.
I may have to start emailing diversified systems, as IFI does not seem to carry them.
  #68   Spotlight this post!
Unread 09-01-2008, 22:03
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
We had a burning smell and got no response. We used a 9V battery.
We confirmed and doubled checked that the wiring was done correctly.
I did the wiring myself and had it doubled check by another Mentor.
We did find the the voltage regulator was lose when we first smelled it.
So we are assume the voltage regulator is fried, faulty or installed faulty.
SO if anyone knows how to get a replacement, or repair let us know.
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
  #69   Spotlight this post!
Unread 10-01-2008, 00:58
keen101's Avatar
Ubuntu Linux User
you just need to somehow find a replacement 5V regulator and replace the old one.
I recommend using a solder sucker to remove the old one. as for finding a 5V L805 or equivalent... I have no idea where to find one. I just salvaged one from some old board lying around. I looked at Radio Shack, but I did not see any.
I have already fixed our board twice. It was the 5V regulator both times.
It's too bad FIRST did not design the board with a diode to prevent accidental reversed polarity.
  #70   Spotlight this post!
Unread 11-01-2008, 11:02
Phalanx's Avatar
Is there any major reason that a 7805 From Radio Shack couldn't be used as a replacement voltage regulator?
http://www.radioshack.com/product/in...rt&tab=summary
The only difference I can see that the factory LM78L05 is limited to 100mA and the 7805 from Radio Shack is 1A. Would this be a bad idea?
Thanks,
Michael
  #71   Spotlight this post!
Unread 11-01-2008, 11:08
keen101's Avatar
Ubuntu Linux User
hmmm......... it might have been the 7805 one, that I used. I can't remember, and I don't have my board with me right now.
  #72   Spotlight this post!
Unread 11-01-2008, 13:21
Engineering Mentor
You'd have to make sure that the pins on the connector would actually fit in the holes for the regulator, but other than that, it should work from an electrical standpoint.
However, I don't know if this would be allowed by FIRST rules, so I would contact them first.
  #73   Spotlight this post!
Unread 15-01-2008, 04:38
dlotts dlotts is offline
FRC #1418 (Vae Victus)
dlotts is an unknown quantity at this point
Send a message via ICQ to dlotts Send a message via AIM to dlotts Send a message via MSN to dlotts Send a message via Yahoo to dlotts
Our board worked for at least 30 minutes. Then the next time we tried it appeared completely non-functional, with no LED's lighting. Maybe the ground and plus voltage got switched one time, we don't know.
We tested the voltage at the inputs, and they were correct.
Then we tested the voltage across the PIC chip at the Vdd and Vss pins. It showed a consistent 0.36 volts -- way lower than the expected 5.0V. We read the same voltage between the ground and the output of the regulator.
We de-soldered the regulator, and replaced it with a larger 7805 regulator that we had on hand, probably 1 Ampere. We used short pieces of wire so we didn't have to make the larger part fit.
Since we'll probably want to have a second one on hand at the competition, we figured we didn't have much to lose by attempting to repair it.
Then the school kicked us out and we didn't get much chance to clean up our solder and try it.
I'll let ya know how this worked out later.
MrLotts.
  #74   Spotlight this post!
Unread 15-01-2008, 07:24
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
MrLotts.
This sounds exactly what happened to us. Please tell us if you get it working. Also, I called FIRST yesterday, and they said they sent a shipment of the IR boards to Innovation First, and that they should appear some time today. Whether or not this is true, I'm going to keep on eye open for them.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
  #75   Spotlight this post!
Unread 15-01-2008, 12:03
keen101's Avatar
Ubuntu Linux User
Thanks,
Michael
If you can get it soldered to the board, then I think it will be fine. I think it's perfectly legal, since you aren't changing the function of the IR board. It is certainly a beefier regulator, but it should work.
Learn C, C++, and Java with new board game. Elgin Clock Programming 8 04-11-2005 13:28
problems with G22 JMH Electrical 2 19-01-2005 20:52
Problems with referees?! LauraN General Forum 16 22-03-2004 17:05
School Board Problems Matthew_H General Forum 47 16-03-2004 18:32
