Go to Post Every game design should be a means to an end. - Mark McLeod [more]
Unread 14-01-2008, 20:31
Pneumaticsman's Avatar
Pneumaticsman Pneumaticsman is offline
AKA: Mitch guzman
FRC #1566 (Ammoknights)
Pneumaticsman will become famous soon enoughPneumaticsman will become famous soon enough
Send a message via MSN to Pneumaticsman
Post 80 inch diameter?
In the manual, <R16> to be exact, it says that the robot may expand up to a total of 80 inches. Now does that mean that we have 80 inches from the center of the robot, the end of the robot, or do we basically have an 80 inch imaginary bubble around the robot?
Thanks
Unread 14-01-2008, 20:34
Re: 80 inch diameter?
Thanks
80" end to end, unlimited height.
Unread 15-01-2008, 08:44
GaryVoshol's Avatar
Cogito ergo arbitro
80 inches maximum horizontal dimension - which is probably across your robot on a diagonal.
(since 2004)
Unread 15-01-2008, 08:48
65_Xero_Huskie's Avatar
65_Xero_Huskie 65_Xero_Huskie is offline
One T
AKA: Mat
65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute
This is correct, however, if you were to get tipped and your robot was "stretched unlimitedly", you would get called for the 80". It happened last year
Min-Max to the Max!
Unread 15-01-2008, 08:54
Kims Robot's Avatar Unsung FIRST Hero
Kims Robot Kims Robot is offline
Onto a New Chapter...
AKA: Kim O'Toole Eckhardt
Kims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond repute
Send a message via AIM to Kims Robot
Be careful with the 80" rule, the Q&A were updated yesterday:
http://forums.usfirst.org/showthread.php?t=8160
http://forums.usfirst.org/showthread.php?t=8159
With these explainations:
As noted in Rule <R13>, Standard Bumpers (and other items such as the battery, etc.) are considered part of the Robot, and must comply with all applicable rules. Based on that, the Standard Bumpers are included when determining if a Robot is in compliance with Rule <R16>.
The rule states that the Robot may not have any two points more than 80 inches apart when measured horizontally. The parenthetical phrase is intended as a clarifying example, but it does not convey the same authority as the rule. It is recognized that a small set of configurations exist (with an equilateral triangle with 80 inch sides as the degenerate case) that are in compliance with the letter of the rule, but may violate the example. In all such cases the rule, and not the example, will be enforced.
~kim~
Kimberly O'Toole Eckhardt <3
Principal Systems Engineer & Program Manager
History - Team 176, Team 229, Team 1511, FIRST Volunteer!!
My new FIRST Photography Hobby & Angry Eric's Fan Page
Excellence - is the result of caring more than others think is wise, risking more than others think is safe, dreaming more than others think is practical, and expecting more than others think is possible.
3 inch Mechanums CraigHickman Inventor 1 21-09-2006 19:18
[OCCRA]: diameter mikaela50 OCCRA Q&A 1 28-09-2005 19:34
Going over 6 inch step with 12 inch wheels Joe P Technical Discussion 25 12-04-2004 11:15
Goal Diameter Bremma Technical Discussion 2 13-01-2004 06:23
Pipe Diameter archiver 2001 1 23-06-2002 23:45
