#9
Re: Can you apply an assembly extrusion to a part?
John - an assembly feature will not make changes to individual part files. If you edit a specific part in the context of an assembly by making an extruded cut in the part THAT is different from making an ASSEMBLY feature.
As JD says: Pay attention to where you are making your edits. |
| Can the VEX controller be programmed in assembly? | Capt. Quirk | Programming | 7 | 23-12-2007 09:31 |
| Assembly to Part | Zoheb N | Inventor | 8 | 07-02-2007 01:26 |
| Can we use part of a container on our robot? | Rick | General Forum | 1 | 10-02-2003 20:10 |
| Can I reduce the number of similar part files? | roknjohn | Inventor | 2 | 29-01-2003 21:36 |
| How much can the window assembly lift? | archiver | 2000 | 9 | 23-06-2002 22:59 |
