Go to Post Admitted to MIT '14. FIRST is good stuff. - sparrowkc [more]
Unread 15-01-2008, 10:10
Kims Robot's Avatar Unsung FIRST Hero
Kims Robot Kims Robot is offline
Onto a New Chapter...
AKA: Kim O'Toole Eckhardt
Kims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond repute
Send a message via AIM to Kims Robot
Drivetrains: Pushing Power?
Im working with a Project Lead the Way EDD class that is working on different drivetrain designs (bunch of FIRST students experimenting!). I have them running several calculations on the drivetrains, speed, traction, etc.
We went through several of the drivetrain presentations I've found on the FIRST site, from conferences and here on CD, and have been unable to find a way to compare the "Pushing Power" of different drivetrain designs (theoretically). Im thinking it has to do with the stall torque of the motors, but how do you factor in when you have multiple motors? How about using the friction of different wheels? Is there a good way to calculate this and compare the drivetrains?
~kim~
Kimberly O'Toole Eckhardt <3
Principal Systems Engineer & Program Manager
History - Team 176, Team 229, Team 1511, FIRST Volunteer!!
My new FIRST Photography Hobby & Angry Eric's Fan Page
Excellence - is the result of caring more than others think is wise, risking more than others think is safe, dreaming more than others think is practical, and expecting more than others think is possible.
Unread 15-01-2008, 10:20
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Drivetrains: Pushing Power?
I like how 842 does it, they lean a bathroom scale up against a wall and see how many pounds the scale says as the robot pushes against it.
Unread 15-01-2008, 10:35
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Kim,
JVN's 2008 spreadsheet (found in the white pages) does that exact calculation for you. He compares the maximum torque from the gearbox and chain reduction to the actual frictional force from the wheels, and uses the lower of the two numbers to determine your maximum pushing force. The spreadsheet even has the ability to combine multiple motors.
The difficulty is determining the Co of Friction for the various wheels, surfaces, etc... That's where FRC842's bathroom scale and immovable object help out.
Good luck,
Bengineer
Unread 15-01-2008, 10:41
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Kim, I attempted a simplified explanation of how torque relates to pushing power here.
I know you've already surveyed the White Papers here on CD. You might want to spend some time playing with JVN's 2008 mechanical design calculator.
Richard Wallace
since 2003
Unread 15-01-2008, 11:59
Thanks, I hadnt looked in detail at the design calculator, I will give that a shot. The biggest thing is that I want them to UNDERSTAND it, rather than just throwing some numbers in a spreadsheet... So I think I will try to borrow the formulas and explain it to them before I show them the sheet.
Richard - thanks for the reference to the post, I will see if that helps them make more sense of it!
And as for the bathroom scale, they have come up with ways of "testing" but Im trying to get them to do the true engineering... DESIGN it first, then see if your calculations match what the real measured values are... if not, why??
Thanks for the help so far!
~kim~
Unread 15-01-2008, 12:01
MrForbes's Avatar
AKA: Jim
Yes, I was a bit hasty to suggest that first, you definitely should do the engineering first, then test it!
Unread 15-01-2008, 12:11
AdamHeard's Avatar
Lead Mentor
Like mentioned before, it's based on the stall torque provided by the motors and the maximum traction force, whichever is lower.
For the force the motors can provide, calculate the torque at the wheel, and divide it by the radius of the wheel (T = F x D.... so F = T/D.... D is distance).
For the maximum traction force, you must lookup/experimentally determine/calculate the Coefficient of friction of the wheels and multiply that by the weight of the robot. Hopefully this number is the smaller of the two.
Now, that's just theory; I'd expect it to be off by a little bit when measured 842 style.
pic: PUSHING MATCH Kyle A Extra Discussion 6 13-05-2006 00:13
Defense: Pushing and Blocking d.courtney General Forum 39 18-02-2006 20:35
Maximum Pushing Force mzitz2k Technical Discussion 3 01-01-2004 11:12
Pushing power with out breaker popping rlowerr_1 General Forum 13 23-07-2003 01:22
Team 190 pushing..... Tom Schindler Robot Showcase 6 21-02-2003 16:50
