Go to Post Our thanks does not have to come from their lips. It comes from the finished product that walks across the stage, gets their diploma and moves on to bigger and better things. - Koko Ed [more]
Unread 15-01-2008, 16:55
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
Re: Can you apply an assembly extrusion to a part?
Originally Posted by Molten View Post
It will, if you do it properly. That is one of the advantages of Inventor. It can be finicky though. Sometimes it will do this on it's own. Sometimes, it will refuse altogether. My suggestion is that if it is refusing...
I have never seen this behavior - post an example dataset if you can.
Copy and paste is whole 'nother ballgame.
Autodesk Inventor Certified Expert
Certified SolidWorks Professional
AU 2007 Avatech Altogether Smarter Inventor Challenge 1st Place
http://home.pct.edu/~jmather/content..._tutorials.htm
Can the VEX controller be programmed in assembly? Capt. Quirk Programming 7 23-12-2007 09:31
Assembly to Part Zoheb N Inventor 8 07-02-2007 01:26
Can we use part of a container on our robot? Rick General Forum 1 10-02-2003 20:10
Can I reduce the number of similar part files? roknjohn Inventor 2 29-01-2003 21:36
How much can the window assembly lift? archiver 2000 9 23-06-2002 22:59
