Go to Post Removing too much of the challenge removes too much of the accomplishment when you solve the problem. Removing too much of the challenge removes too much of the innovation in the solutions... removing too much of the challenge removes too much of the fun. - dlavery [more]
Unread 15-01-2008, 08:51
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
Field-Oriented Mecanum Drive
An interesting idea I had:
http://web.mit.edu/first/www/semiOLcontrol.pdf
Should give a non-drifting absolute heading. The trig for rotating frame of reference is done off-board to save processor time, sent as analog signals of the sin and cos. This way, all the math done on the RC is straight multiplication.
It looks closed-loop, but it's actually more of an open-loop controller, in that you still trust the Mecanum algorithm to do what it is supposed to do. So, proper weight balance and such still important. The only direct feedback is to cancel out undesired rotation, which seems to be the biggest problem with Mecanum drive.
Feasible? I know I've seen field-oriented drive before. Any tips? Anyone tried something similar with success?
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
Unread 15-01-2008, 08:55
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Re: Field-Oriented Mecanum Drive
This looks pretty feasible.
I like the idea of outsourcing all of the heavy math to a co-processor. The flow chart makes it very clear.
If we hadn't vowed not to use mecanum this year, I think I'd give this a try
Jacob
Unread 15-01-2008, 10:09
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Looks slick.
Using look-up tables for the trig functions, it's not hard to do this in code if you want to go that direction.
Unread 15-01-2008, 11:27
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Team 190 did a field oriented control system with mechanum drive for the 2k4 competition. One of the most important things is keeping all 4 wheels on the ground at all times. I wasn't too involved with the system that year, but some of the others on the team might be able to fill you in.
Unread 15-01-2008, 12:12
ZZII 527's Avatar
AKA: Shane Colton
FRC #0097
Thanks. I got an email from Mason (190 alum, do you know him?) about it and he gave me some good tips. Looked really cool in '04 (or was it '05? or both?).
Unread 15-01-2008, 12:17
rachal's Avatar
rachal rachal is offline
multipurpose tool
AKA: Rachel
FRC #1072 (Harker Robotics)
rachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nice
Send a message via AIM to rachal
Looks nice. We got pretty decent field-oriented control with a magnetic compass last year. (Although the bot went crazy every time we drove by this one locked door in the hallway at school.)
2005 Sacramento Winners with 245 and 766
2005 SVR Semi-Finalists with 840 and 668
2005 SVR Judges Award
Unread 15-01-2008, 16:56
Matt C's Avatar
FRC #1468 (J-Birds)
Yea, was 2k5, I was getting years confused.
Mecanum Drive - Help Smoking_Gun Programming 22 04-12-2007 20:51
Field oriented holonomic code? chaoticprout Programming 4 24-01-2007 23:09
mecanum drive system Charger_07 Technical Discussion 5 23-01-2007 19:20
Mecanum Drive Technique Dan Petrovic Technical Discussion 9 16-08-2006 20:42
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
