#16
Re: Our robot is done!
Don't foget that you must have your flagholder at least 51" high!!
#17
For the flag holder : there's four inches from the back of the scissor lift to the back of the limitations that the flag will fit on. we had to allocate the room especially.
![]() As for hurdling when we get to the top : the manipulator goes up with the lift, so with a slope and lowering that over the first bar, the ball should roll right over, as long as we position it right. And most people are correct, we don't plan to want to knock the ball off explicitly, but we do think with the cradle on there we will be able to actuate the scissor lift when we are -underneath- the rails to be able to hit it, it's not something we're designing for yet, and if we are able to do it it's a nice accessory ;P |
#18
It sounds like you're in great shape
I hope your testing goes well. |
#19
Fantastic design! This allows for a good defensive build and the ability to hurdle! Great! One question- how long does it take to extend the scissorlift to hurdling position?
#20
Good question, haha, I'll get back to you. From preliminary tests with actuators it seems like it will go up rather fast, and we actually may have to run down the pressure from max on these things. We're now using, after more testing today, 2 2 inch bore 12 inch stroke actuators, and we plan to tweak with the psi to get them to run at a reasonable speed. I don't see speed being an issue though, and we're shooting for, I don't want to sound unrealistic as I suppose I don't really know exactly, but maybe around ~6 seconds? Five? I'll let you know as the weeks progress.
#21
Go with the scissor lift. We did that in 2005 and it worked great. The only problem was our drive base... >< But, we did win the Engineering Inspiration Award with it.
First rookie team to ever win it! Anyway, it was awesome. |
#22
Since the two claws only look like they are about 0.5" diameter aluminum tubing, as soon as another team runs into those, or your driver accidentally runs into the wall at the far end of the playing field, they are going to be bent. There are only so many times you can bend them back until they snap. |
#24
Seems like a good idea. Seriously going for a scissor lift? Good Luck!
What happened to your real trackball? Did it pop? |
#25
Camtunkpa, yeah sorry, that's what I meant... I said psi but I was thinking of those =/.
Oh, that's -definitely- a prototype manipulator. Thanks for the input though, we plan to make that muchh more rigid, probably using ~3/4 or 1 inch square tubing in the end. Heheh. ... and yeah our ball popped. =( oye. new ones tomorrow hopefully. |
#26
if that was really your final design, i would eat my hat
#27
YEP That is right GOOD LUCK from Team 88 TJ2 and MOE ![]() |
#28
Get ready to eat your hat then. ;P
Seriously though, unless we find a major flaw, this is the -design- we are going to go with. Not the exact mechanisms or anything... but as I said those are the ideas we are running with. Last edited by Brad Voracek : 16-01-2008 at 23:50. Reason: typo |
#29
You will be in the finals for sure!
#30
how fast will your robot go in feet per second
| pic: 233 robot teaser, yep, theres our robot ; ) | ducttapedude | Extra Discussion | 20 | 15-02-2007 22:02 |
| pic: This is our robot as of last night. Alot more should get done this week now that things are in place | dfukuba | Extra Discussion | 28 | 25-01-2007 13:14 |
| pic: 1067's robot (almost done) | CD47-Bot | Robot Showcase | 8 | 17-02-2004 21:41 |
| IS your robot done? | team222badbrad | General Forum | 21 | 08-02-2003 18:41 |
| Robot done! | archiver | 2001 | 3 | 24-06-2002 00:23 |
