Go to Post This year may be one of the first years where there is a drastic difference in Regional level and Championship level strategies that drive robot design. - tim-tim [more]
  #211   Spotlight this post!
Unread 14-01-2008, 15:59
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
Re: New C18 3.0+ Compatible FRC Code
Originally Posted by Kevin Watson View Post
My thought was to not even have an ISR and just keep an eye on your 100Hz timer interrupt flag with code located in teleop_spin() and/or autonomous_spin(). Just setup and start a timer, but don't set the interrupt enable bit to one, which will prevent the processor from calling the low priority ISR. Then with code like this in *_spin():
if(INTCONbits.TMR0IF)
// Get encoder counts
// Calculate position/velocity
// Do PID calculations
// Update PWM values
//reset interrupt flag
INTCONbits.TMR0IF = 0;
...you can implement your 100Hz contol algorithm.
-Kevin
Ahh. I understand. No ISR at all. That would make it run slightly slower than 100hz, but will probably help performance slightly (due to the lack of the ISR). Thank you very much.
EDIT: Actually, I am not sure if it will run any more slowly at all. This looks great.
EDIT 2: Timer 0 does not seem to have the support to run to a predetermined value like timers 2,3,4. Should we use timer 2 instead? Another question. None of these timers actually allow us to run a 100hz cycle, even with 1:16 pre- and post-scalers. The slowest we can do is 150hz. Am I missing a way to do it, without using a second flag, or should we just use 150hz (or a double flag)?
EDIT 3: I just ran into another potential obstacle. Our calculations say that we will get at most 15 ticks from the encoder per cycle. That does not seem like a very high resolution. We're currently trying to see if this will actually be an issue, and if so, what we could do about it.
  #212   Spotlight this post!
Unread 14-01-2008, 22:26
spack spack is offline
spack is an unknown quantity at this point
I see the linker problem when enabling some but not all of the encoders in the 3 to 6 range.
Chad
  #213   Spotlight this post!
Unread 14-01-2008, 22:42
The ISR linker issue occurs if encoders_3 and beyond are enabled because...
ENABLE_INT_3_6 must be defined in ifi_frc.h, in order to use encoders in the range 3_6
This causes 'calls' to the ISR routines from ifi_frc.c lines 326 to 338.
But if this code block is enabled, all the interrupt code must exists in encoder.c.
That only happens if ENABLE_ENCODER_3 through ENABLE_ENCODER_6 are ALL defined in encoder.h which compiles in ALL the ISRs in encoder.c.
The define hierarchy needs to be fixed, or use all of 3_6 ISRs or none of them.
Chad
  #214   Spotlight this post!
Unread 15-01-2008, 01:43
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Yep, it doesn't quite work correctly. Thanks for catching my gaff. I'll have an update probably tomorrow.
-Kevin
Kevin Watson
http://kevin.org
  #215   Spotlight this post!
Unread 15-01-2008, 14:40
billbo911's Avatar
billbo911 billbo911 is online now
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
-Kevin
Kevin,
First I would like to say, Thank you in advance.
Is it possible that once you make this modification to the project files and post them, that you could also list the files that were modified so we would be able to just copy the modified files into our already customized projects and then just rebuild. It would save quite a bit of time if we didn't have to make all the customizations again. If not, no sweat, we could always use the practice.
  #216   Spotlight this post!
Unread 15-01-2008, 16:26
FRC #2429
Does it give anyone heartburn if I just release one build for each of the two compiler versions that has support for the ADC, gyro and encoders already built in? You'd be able to remove funtionality by commenting out a few #defines.
-Kevin
Kevin Watson
http://kevin.org
  #217   Spotlight this post!
Unread 15-01-2008, 16:28
bronxbomber92 bronxbomber92 is offline
FRC #1551 (Grapes of Wrath)
bronxbomber92 is an unknown quantity at this point
I have no problem with that.
  #218   Spotlight this post!
Unread 15-01-2008, 16:40
billbo911's Avatar
Does it give anyone heartburn if I just release one build for each of the two compiler versions that has support for the ADC, gyro and encoders already built in? You'd be able to remove functionality by commenting out a few #defines.
-Kevin
IMHO, that would be ideal!!!
I don't mind hacking together various functions, in fact, I have learned a lot by doing this in the last couple years. But, if it is together already, it would be VERY convenient!
  #219   Spotlight this post!
Unread 15-01-2008, 17:09
michelita2607 michelita2607 is offline
FRC #1988
michelita2607 is an unknown quantity at this point
I know this might be kinda random, but does anyone know if we are allowed to use any kind of gps system in our robot sense it's location on the field?
  #220   Spotlight this post!
Unread 15-01-2008, 17:36
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
-Kevin
This seems like a more efficient approach for both you and people using the code.
  #221   Spotlight this post!
Unread 15-01-2008, 19:37
d235j d235j is offline
FRC #4454
d235j has a spectacular aura aboutd235j has a spectacular aura about
This post is irrelevant to this topic, but in any case GPS is too inaccurate for this use. Also, it involves receiving external communications, which I understand is against the rules.
  #222   Spotlight this post!
Unread 15-01-2008, 21:43
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
-Kevin
Excellent idea!
BTW, would you think that using 4 interrupts,INT's 3-6, at 128 ints/sec (every ~8ms) would be overstressing the processor? My students want to control our mecanum drive with an encoder on each wheel; I favor the gyro approach.
Thanks again for your work for the teams!
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
  #223   Spotlight this post!
Unread 16-01-2008, 00:04
comphappy comphappy is offline
AKA: Brennan Ashton
FRC #2605 (A2D_16)
comphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to behold
Send a message via AIM to comphappy
How are people implementing these updates?
  #224   Spotlight this post!
Unread 16-01-2008, 04:38
-Kevin
We would definitely prefer it that way.
  #225   Spotlight this post!
Unread 16-01-2008, 08:36
-Kevin
That sounds good. Doing code management through a one way CVS or some such code repository arrangement where our work can be locally merged but we can stay up to date with you would be nice
Chad
Does the camera code suits to all versions of MPLAB and C18? razer Programming 3 04-01-2007 14:50
Trying to follow C18 interrupt context code... dcbrown Programming 5 21-12-2006 09:01
Error w/ FRC code JamesBrown Programming 2 08-01-2005 16:17
Programming code Fix FRC Ferazel2001 Programming 6 08-02-2004 02:46
FRC default code hedgehogger Programming 2 21-01-2004 18:41
