Go to Post Stacking totes on end; Gives you extra height, alas; Topples with a sneeze. - BethMo [more]
Unread 15-01-2008, 19:48
duhoverdrive's Avatar
duhoverdrive duhoverdrive is offline
FRC #0549
duhoverdrive is an unknown quantity at this point
Exclamation Import default to Easy C
How do you import the default source for Easy C?
If tapped a Chuck Norris roundhouse kick can power the continent of Australia for 45 minutes. Chuck Norris CAN slam a revolving door.
Unread 15-01-2008, 22:03
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: Import default to Easy C
There is no default code for EasyC, besides the FRC Competition Template.
Once you open the Competition Template, you just start adding in your own code. The default code (WPILib) is in the background and takes care of everything for you.
Art Dutra IV
世上无难事,只怕有心人.
Unread 15-01-2008, 22:47
taggartbg taggartbg is offline
FRC #1712 (Dawgma)
Team Role: Electrical
taggartbg will become famous soon enoughtaggartbg will become famous soon enough
Send a message via AIM to taggartbg Send a message via MSN to taggartbg Send a message via Yahoo to taggartbg
Once you have your code, get the serial cable to interface your computer with your bot.
1) Plug in that cable to the bot and the computer
2) Turn the bot on, make sure your radio is unplugged
3) Hold down "Prog" on the microcontroller until the "Program Status" LED turns orange
4) Go to "Build & Download" in easyC, and click "Build & Download"
5) Once the hex file is built, hit "yes"
6) Success? It's loaded into the bot, plug your radio in and try it out.
Default Code to Easy C bcharbonneau Programming 3 14-06-2011 01:31
Import/Export in Solidworks Mr. Steve SolidWorks 8 28-02-2010 16:01
easy c default program? bos1ex Programming 9 30-01-2007 22:12
Import Game Store Atasuke768 Chit-Chat 0 12-04-2005 18:24
import to 3ds rmmlg Inventor 0 18-04-2004 18:22
