Go to Post Don't try to kiss your stapler remover, those prongs are sharp... - MissInformation [more]
  #31   Spotlight this post!
Unread 15-01-2008, 21:06
SSMike's Avatar
SSMike SSMike is offline
The Guy with the Big Blue Two
FRC #0250 (The Dynamos)
Team Role: Operator
SSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond repute
Re: FRC too easy...we're done :)
Originally Posted by Kittybot View Post
Well, if your 'bot was never done, you'd never go to contests, right?
What they mean by that is that, no matter what, you will be changing things, realizing something doesn't work and scrambling trying to figure out how to make it work. As Bobby said, a key part of the engineering process is to design and optimize. When you test, you'll more than likely see that you need to change some parts in some way. So technically, you're never really done.
Also congrats to those who have finished their robot so early.
Long Live #4
Just when I find the key to success, someone goes and changes all the locks.
"It's kind of fun to do the impossible" -Walt Disney
When you put 'THE' and 'IRS' together, it forms 'THEIRS'. Coincidence? I think not!
Why is the name of the phobia for the fear of long words: hippopotomonstrosesquippedaliophobia?
"There's no such thing as a winnable war......." Bring our Troops Home
I will never let you fall
I'll stand up with you forever
I'll be there for you through it all
Even if saving you sends me to heaven
--The Red Jumpsuit Apparatus
  #32   Spotlight this post!
Unread 15-01-2008, 21:09
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
Wrong-o. Competition is not the end of a 'bot's life (usually). We're using our '07 bot as a presentation 'bot (and when we finish '08 we'll use both of them, '07 is a ramp bot so we can demonstrate some of the stuff that FIRST has us do).
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
  #33   Spotlight this post!
Unread 15-01-2008, 22:42
Donny_Fresh Donny_Fresh is offline
no team (Freshies and the rockets)
Rookie Year: 1987
Donny_Fresh will become famous soon enough
Smile We're DOne for sure!
ok so we just finished putting together the final touches on our robot. Like i mentioned before we're done. we took it apart today to make final measurements and final adjustments. The reason we were able to finish our robot so quickly was because we've been working on rolling chasis for almost a year now getting the right design together to optomize the torque output for the 6 wheel drive. We built a test track within 2 days of the kick off and made numerous efforts to make sure our robot would be able to go around this w/ ease. we then tested it in a full field of robots and even so we're able to make about 80 points with a tolerence of about (+-)10 points and we're planning on racking in about 15-20 points in the hybrid mode.
Our design is so simple yet it works so effeciently and so well that there's no doubt in my mind that it'll work to its full potential, but ill save that for the comp in april.
anyway to all those teams who said we wern't done well i mean no offense but when we say we're done we're done. we've got everything from fundraising to giveaways, to students very well informed of the rules and everything else.
finally ill have a picture of the robot posted within the week...most likly thursday. anyway good look to all the teams...give us some feed back, tell us how ur doing!!!
  #34   Spotlight this post!
Unread 15-01-2008, 22:49
Brad Voracek Brad Voracek is offline
.999~=1
FRC #0399 (Eagle Robotics)
Brad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of light
Send a message via AIM to Brad Voracek
Re: We're DOne for sure!
Wow! Sounds like you guys have the perfect robot after only a week and a couple days! Pretty amazing.
... in fact sounds like you have perfect everyything! Did you guys have help? This is a pretty good feat for a rookie team, because as a ninth year team we've never had a robot even close to done til week 4.5.
Care to elaborate on your manipulator, if you have one? Or do you plan to just drive around? I suppose it's feasible to just have a driving robot by now, but you guys don't plan on going beyond? Come on! You guys have 4.5 weeks left. Enough time to build a whole other robot! And you made sure that you rebuilt everything once the six weeks started right? Because you aren't supposed to build things before hand . . .
.999~ (Repeating) is equal to one (1).
Team 399 - Eagle Robotics
  #35   Spotlight this post!
Unread 15-01-2008, 22:51
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
ummm just a question.. you said you worked on this design for a year, did you pre build it?? cause it is against the rules to do that, and it seems really hard for me to believe that your bot was finished in a week and a half we what sounds like a trackball manipulator designed and built.
If you managed to do that, then congrats! If not I hope you have plans to rebuild it now lol!
  #36   Spotlight this post!
Unread 15-01-2008, 22:57
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
70-90 points in a full field of robots? Without hybrid? I'm sorry my friend, but I'm going to have to disbelieve you. I also have to mention that using any parts machined, bought, or created before kickoff is illegal.
But eighty points? I can't see it. Assuming you can place the ball in the end, you'll need 68 more points. That's seven laps when hurdling, seventeen with herding, and 34 when just driving. If you hurdle, we're still talking about making at least seven laps (+ last one to plae the ball). To me, that means that in just over seventeen seconds, you guys can pick up a huge ball that will be bouncing around, nagotiate around five other robots and three other balls, and toss or lift the ball over the overpass. I'm sorry, but I just don't see that happening.
Surprise me. I'd love to see a team put up 80 points in the teleoperated mode. But I just don't see it happening. The most I'd believe a team can put up is 60 points (without Hybrid), and that's with six hurdled laps and placing the ball in the end.
Good luck.
  #37   Spotlight this post!
Unread 15-01-2008, 23:05
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
hmmm....80 points would be 10 laps in 2 minutes with a hurdle on every lap. So, that means 1 lap every 12 seconds. The distance around the track at its shortest dimension is about 70 feet (30 or so for each long side, and 5 or so for each sort side). That means a speed of about 6 feet per second with instant acceleration, perfect turns, and perfect action of the manipulator. Possible, but not likely in just 10 days (even for a team of pros).
Also, it sounds from your post that this light-speed development stems from a one year project. That sounds like minor tweaks to mechanisms or designs that existed before kickoff....hmmmm
-JEE
  #38   Spotlight this post!
run the trap!!!
Team Role: Human Player
I agree. But two robots working together? Well... that’s another story... Imagine two robots just sitting on either side of the finish line. One robot hurdles, the other robot catches the ball and rolls it back over the finish line (without any part of the robot passing through the finish line of course). The hurdler picks up the ball again and repeats the process... BIG points.
-Philip J. Fry
  #39   Spotlight this post!
Unread 15-01-2008, 23:07
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
That has, of course, been thought about by the GDC and has, of course, been made illegal (I'll try to find the rule in a second, something about the ball having to cross the opponents finish line before it crosses your own again)
  #40   Spotlight this post!
Unread 15-01-2008, 23:09
.999~=1
Yeahh. when they were doing it in the game animation it was just to roll it back so he could get more points by placing it on top, you wouldn't get points for knocking that ball down again.
  #41   Spotlight this post!
Unread 15-01-2008, 23:14
danshaffer's Avatar
danshaffer danshaffer is offline
Stanford 2012
AKA: if it quacks like a duck...
danshaffer is just really nicedanshaffer is just really nicedanshaffer is just really nicedanshaffer is just really nice
Yup. The ball must cross the other finish line before re-crossing its own for more points.
FRC8 Co-Captain 2007-2008
FRC8 Mentor 2008-present
CalGames Ref 2008, 2009
Stanford 2012, Computer Science
  #42   Spotlight this post!
Unread 15-01-2008, 23:31
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
BUT, (correct me if I'm wrong) after it crosses the opponent's line, you can hand it over the middle to a team's robot. That's unless they changed the rules and I haven't noticed.
Also, there's no freakin' way on God's green earth that I would even think about believing your claims. Like mentioned before, it's plausible that you would have a box just for driving by now.
AND, lastly, I truly hope that you didn't use any chassis/drivetrain you fabricated before kick-off. It'll be very dissappointing to your team.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
  #43   Spotlight this post!
Unread 15-01-2008, 23:41
.999~=1
Correct. I haven't seen anything that disallows this either.
... I'm not sure many people believe him. But it's always fun to go with the notion that someone isn't joking around and is pretty amazing! ;P
  #44   Spotlight this post!
Unread 15-01-2008, 23:54
dsm dsm is offline
dsm will become famous soon enoughdsm will become famous soon enough
Forum + Anonymity = Rampant Exaggeration, if not outright Blatant Lying. Welcome to the internet, please enjoy your stay.
  #45   Spotlight this post!
Unread 16-01-2008, 00:34
synth3tk's Avatar
AKA: David Thomas
....says the newbie with one post.
Do we Have To Know Standard C or only basic C with easy c on FRC? jesusescobar Programming 3 21-01-2007 23:00
FRC easy-c vex encoder function? Gdeaver Programming 2 23-01-2006 08:03
Easy C for FRC Tutorial Amin Programming 1 18-01-2006 17:43
FLL in Miami, FL - an opportunity (and maybe FRC too) Andy Baker FIRST Lego League 0 17-10-2005 15:25
pic: we're done Brendan_710 Robot Showcase 17 24-01-2005 05:46
