Go to Post Make sure you THOROUGHLY understand the rules of the game before you actually start designing the robot. - Koko Ed [more]
Unread 15-01-2008, 20:54
Pneumaticsman's Avatar
Pneumaticsman Pneumaticsman is offline
AKA: Mitch guzman
FRC #1566 (Ammoknights)
Pneumaticsman will become famous soon enoughPneumaticsman will become famous soon enough
Send a message via MSN to Pneumaticsman
Post IR during teleopertated period?
We just came across an interesting thought. Could we use the remote control during the teleoperated period?
Thanks
Unread 15-01-2008, 21:20
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: IR during teleopertated period?
Now you're thinking.
Unread 15-01-2008, 21:25
IbleedPink233's Avatar
IbleedPink233 IbleedPink233 is offline
FRC #0233 (The Pink Team)
IbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to behold
The rules states pretty clearly that you can, but you have to think about a few things: IR range is limited and subject to interference, so the radio control will always be more dependable; not only that, but interactive control from the driver station will always beat out whatever automated actions you have programmed in the robot, simply because it is more flexible (you can actually effectively counter defense). So I don't think that the IR will be very useful for controlling the robot during the Teleoperated Period.
Of course, I do have an idea about how it could be used, but it's a secret. . .
Unread 15-01-2008, 22:58
Jaybee1405
Posts: n/a
I was thinking the only useful reason to do this is if you have your Robocoach in the satellite station and he helps turn if the teleop driver's vision is impaired because of the distance and/or another robot is blocking the view.
Unread 15-01-2008, 23:14
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
One problem with using it during teleoperated mode would be if the driver is trying to do something and the ROBOCOACH thinks he will be "helpful" and send a signal it could really get annoying to the driver when the robot starts moving when he/she isn't wanting it to move...
Unread 16-01-2008, 08:57
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
You can trigger certain autonomous routines from a switchor something on your control board...I'd recommend doing that. Like people said before Radio is much more reliable than IR.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 16-01-2008, 09:11
This would definitely be a big problem if the Robocoach is in the remote station (remote as in distant, the GDC should have chosen a less ambiguous word), where they can't communicate with the drivers well.
This problem could also be fixed in software by making the radio control override the coding from the remote - so that the driver control always wins and they don't have to worry about fighting the will of the Robocoach.
Unread 16-01-2008, 10:53
mole mole is offline
AKA: Anmol Dhar
FRC #0772 (SabreBytes)
mole is an unknown quantity at this point
yea our team was thinking of a way to increase the range of the ir signal
it would be pretty useful to have the robocoach on the otherside of the field helping the driver when he can. You might need to find a way to communicate with each other though.. I was thinking of some ways of doing that
Good Luck
Unread 16-01-2008, 20:36
Aubreii's Avatar
Aubreii Aubreii is offline
Nerdfighter
AKA: The guy who ate Lithium Grease...on accident
FRC #2658 (Pedestrian)
Aubreii is an unknown quantity at this point
Send a message via MSN to Aubreii Send a message via Yahoo to Aubreii
Without communication between the RoboCoach and the driver, this seemed to be a pretty useless feature. If your driver can't see 54', even with a few robots between them and their own, they need glasses (like me ). Walky-talkies aren't permitted, but we had thought about a hard-wired system. Myself and another member of our team are also in Theatre Tech, and we both thought of using the headsets we use during shows. However, the infrastructure needed for them ruled that out. If anyone comes up with a way to communicate without breaking the rules, we'd all be interested in hearing it.
Measure once and cut twice....Wait, what?
Unread 16-01-2008, 20:53
Nightfall831 Nightfall831 is offline
AKA: Paul
FRC #0888 (Robotiators)
Nightfall831 will become famous soon enoughNightfall831 will become famous soon enough
Send a message via AIM to Nightfall831
communication would definately be an issue...i found that out recently at a convention we took our robot to...i decided to sit on our bot while i drove it with my remote and the IR board....it was great untill our driver decided he wanted to drive from across the very large room...lets just say i got real friendly with the circuit breaker...
another problem our team has is that if the IR board recieves a command, it locks out the joysticks, so the actual driver loses control of the robot...
i actually just thought of a way to fix that, but god only knows if it will work....programming sucks...
an interesting thought i saw somewhere else was to have the robocoach send signals to the board to send signals to the driver if he cant see, but that seems like a waste of the limited number of commands we have.
That's a PEBKAC problem. (Problem Exists Between Keyboard And Chair)
^Yea, I never run into those...
Unread 16-01-2008, 20:56
Clifford Clifford is offline
AKA: Clifford Harrison
FRC #2658
Clifford is an unknown quantity at this point
Unless you went completely autonomous. But who wants to do that when we've got a brand new toy?
Clifford Harrison, Alumni & Mentor
FRC Teams 2658 & 3749
FTC Team 5135
Unread 16-01-2008, 22:04
popo308's Avatar
AKA: Brent
Exactly i just see it being an annoyance to the driver more than an assistance...
Design Period, THEN Build Period dtengineering FRC Game Design 13 09-06-2007 12:46
Robot Cool Down Period...? Mike Starke General Forum 27 19-03-2007 01:25
8 weeks build period!?! Ken Leung Rumor Mill 18 28-01-2003 21:14
Autonomous Period Andy Grady General Forum 73 20-01-2003 21:34
FIRST Build Period Karl General Forum 5 09-12-2001 13:30
