Go to Post Let's see some love for these fine people. Let's give it up for the refs. - Andy Baker [more]
Unread 15-01-2008, 22:50
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Different Infared commands every match...
Hey, we were curious with Update 3 that just came out does this mean we can not have more than 4 commands on the robot for every match?? E.G. every match we upload a new set of commands?
Unread 15-01-2008, 22:57
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Re: Different Infared commands every match...
well I assume no because you must give the inspector a sheet saying what your codes are, and you only get to write down 4, so I would assume that means you can't change them!
Unread 15-01-2008, 23:11
Remember, Update 3 DID NOT change the Robocoach and signaling rules. Therefore, you could have more than one auto mode, which would require more than one card. There is nothing saying that you can only have one mode.
And you do not have to turn in a list to inspection, you have to show a card in the station.
Unread 15-01-2008, 23:15
FRC #1360
goes to show I didn't read that part of the rules well enough
guess I'm wrong... I'll be going now...........
Unread 15-01-2008, 23:16
popo308's Avatar
AKA: Brent
So in theory we could have a different ROBOCOACH card every match?
Unread 15-01-2008, 23:24
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Could one of your commands on the card be "Toggle power" so if it is already moving it stops and vice versa? You could also do that for a toggle speed? Since its the same button and it is doing the same "Toggle" command would that be allowed?
Unread 15-01-2008, 23:27
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
According to team update 3, the "test" for legality is this:
Does the robot do the same thing every time the button is pressed?
For any kind of toggle, the answer is probably no. So, at this point in time, one button toggles are not a legal RoboCoach command.
Unread 15-01-2008, 23:28
popo308's Avatar
AKA: Brent
I believe you can....
If you are simply telling it while button 1 is pressed go forward until you stop pressing it i think that would be fine....
As far as a go when button one is pressed then stop when it is pressed again...
I would say that violates the rule clarified in Update 3 about how it MUST be the same command every time..
NOTHING TO DO WITH TOPIC NOT WORTH NEW THREAD!
(does anyone here no where to download the 2008 default code??)
THANKS!
Yes. But you need to be sure you have the right card for your auto mode. Wouldn't want you to get penalized for having the wrong actions.
Unread 16-01-2008, 00:01
wt200999's Avatar
Texas Instruments
AKA: Will Toth
I think the 2007 code should work fine. Its all the same as far as I know.
Unread 16-01-2008, 00:08
popo308's Avatar
AKA: Brent
You do have a very good point....
Didn't think of that....
I mainly want the 08' code because it has the IR board already in it so we can just test our system out a bit with it....
Unread 16-01-2008, 02:32
JohnC's Avatar
JohnC JohnC is offline
my other name is nigel
FRC #0360 (360 Revolution)
JohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the rough
Send a message via AIM to JohnC
Huh? Who said there was code with that already in it? Fourth year doing this, and I seriously doubt there will be code with a template for the IR stuff...
What place are we at? ... TODAI!
Unread 16-01-2008, 02:40
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
how about if you press button 1, activate power forward, UNTIL you press button two, which turns it off. so it's not a toggle. Each button does it's one command (Unless it can't be done, like forward can't start if it's going, the bot can't stop if it's not moving) and you get a "toggle" effect (although at the cost of another button/command.)
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 16-01-2008, 09:12
GaryVoshol's Avatar
GaryVoshol GaryVoshol is online now
Cogito ergo arbitro
That's not a toggle - that's two different actions (Go, Stop) on two different buttons. Sounds perfectly legal.
(since 2004)
Unread 19-01-2008, 12:34
RyanW RyanW is offline
FRC #0449 (Blair Robot Project)
RyanW has a spectacular aura aboutRyanW has a spectacular aura about
popo308,
As far as I know, there is no 2008 default code, just like there was no 2007 default code - it's the same as in 2006. The InfraRed sensor board simply hooks up to digital IO pins on the robot.
Relating to Team Update 3, it seems that FIRST still hasn't entirely decided on some things...Toggles are not allowed (although I personally don't see why if it's on-off and therefore equivalent to holding the button), as stated in several Q&A forum responses. However, they have given contradictory responses regarding a "Turn left" command or an "Increment motors" command. The related Q&A posts from team 449 and the answer has been taken down, so I guess we'll have to just wait and see...
pic: Backup battery ends match inside a different robot artdutra04 Extra Discussion 19 22-10-2006 14:46
Infared in Next Year's Game Paradox1350 Rumor Mill 45 02-04-2004 20:45
1075 is planning on videotaping every match at the Canadian Regional... Racer26 General Forum 0 22-03-2004 22:26
Infared sensors???? Devastater Kit & Additional Hardware 1 21-02-2004 19:39
Infared Code TommyT Programming 1 11-01-2004 19:33
