Re: Different Infared commands every match...
Could one of your commands on the card be "Toggle power" so if it is already moving it stops and vice versa? You could also do that for a toggle speed? Since its the same button and it is doing the same "Toggle" command would that be allowed?
Does the robot do the same thing every time the button is pressed? For any kind of toggle, the answer is probably no. So, at this point in time, one button toggles are not a legal RoboCoach command. |
As far as a go when button one is pressed then stop when it is pressed again... I would say that violates the rule clarified in Update 3 about how it MUST be the same command every time.. NOTHING TO DO WITH TOPIC NOT WORTH NEW THREAD! (does anyone here no where to download the 2008 default code??) THANKS! Last edited by popo308 : 15-01-2008 at 23:31. |
I think the 2007 code should work fine. Its all the same as far as I know.
| pic: Backup battery ends match inside a different robot | artdutra04 | Extra Discussion | 19 | 22-10-2006 14:46 |
| Infared in Next Year's Game | Paradox1350 | Rumor Mill | 45 | 02-04-2004 20:45 |
| 1075 is planning on videotaping every match at the Canadian Regional... | Racer26 | General Forum | 0 | 22-03-2004 22:26 |
| Infared sensors???? | Devastater | Kit & Additional Hardware | 1 | 21-02-2004 19:39 |
| Infared Code | TommyT | Programming | 1 | 11-01-2004 19:33 |
