Go to Post "It's not a flashlight! it's an arduino with a really strong status LED!" - Leav [more]
Unread 15-01-2008, 23:28
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Re: Different Infared commands every match...
Originally Posted by wt200999 View Post
Could one of your commands on the card be "Toggle power" so if it is already moving it stops and vice versa? You could also do that for a toggle speed? Since its the same button and it is doing the same "Toggle" command would that be allowed?
I believe you can....
Originally Posted by BigJ View Post
According to team update 3, the "test" for legality is this:
Does the robot do the same thing every time the button is pressed?
For any kind of toggle, the answer is probably no. So, at this point in time, one button toggles are not a legal RoboCoach command.
If you are simply telling it while button 1 is pressed go forward until you stop pressing it i think that would be fine....
As far as a go when button one is pressed then stop when it is pressed again...
I would say that violates the rule clarified in Update 3 about how it MUST be the same command every time..
NOTHING TO DO WITH TOPIC NOT WORTH NEW THREAD!
(does anyone here no where to download the 2008 default code??)
THANKS!
Unread 16-01-2008, 00:01
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
I think the 2007 code should work fine. Its all the same as far as I know.
pic: Backup battery ends match inside a different robot artdutra04 Extra Discussion 19 22-10-2006 14:46
Infared in Next Year's Game Paradox1350 Rumor Mill 45 02-04-2004 20:45
1075 is planning on videotaping every match at the Canadian Regional... Racer26 General Forum 0 22-03-2004 22:26
Infared sensors???? Devastater Kit & Additional Hardware 1 21-02-2004 19:39
Infared Code TommyT Programming 1 11-01-2004 19:33
