Go to Post I'm currently working on design for a bin made out of concrete that will not break for next year's competition... :D - dlavery [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:24
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
STAMP II not responding to computer
Posted by Amol Mittal.
Student on team #115, Monta Vista Robotics Team, from Monta Vista High School and Nasa Ames Research Center.
Posted on 1/9/2000 5:50 PM MST
Hello
I'm trying to connect the Robot Controller to my PC so I can program it.
All the wires are in place and the power is turned on and everything is as it is supposed to be (ithink)
When I run the stamp editor and try to Identify
(ctrl - I), I get the following error :
I don't know what's the problem. The power is on, and the Status LED's are all working.
Amol Mittal
#0047 (ChiefDelphi)
Re: STAMP II not responding to computer
Posted by Jerry Eckert.
Engineer from Looking for a team in Raleigh, NC sponsored by .
Posted on 1/9/2000 6:41 PM MST
In Reply to: STAMP II not responding to computer posted by Amol Mittal on 1/9/2000 5:50 PM MST:
: Hello
: I'm trying to connect the Robot Controller to my PC so I can program it.
: All the wires are in place and the power is turned on and everything is as it is supposed to be (ithink)
: When I run the stamp editor and try to Identify
: (ctrl - I), I get the following error :
: I don't know what's the problem. The power is on, and the Status LED's are all working.
: Amol Mittal
You appear to have omitted the error message text from your post.
The three obvious things to check:
1. that the programming utility is set to use the same port you are physically connected to
2. that you are set to use the correct baud rate
3. that your interface cable is good.
#0047 (ChiefDelphi)
Posted by Steve Shade.
Other on team #7, Wizzards, from Parkville High School and Black & Decker / AAI / Raytheon.
Posted on 1/9/2000 8:42 PM MST
In Reply to: Re: STAMP II not responding to computer posted by Jerry Eckert on 1/9/2000 6:41 PM MST:
: The three obvious things to check:
: 1. that the programming utility is set to use the same port you are physically connected to
: 2. that you are set to use the correct baud rate
: 3. that your interface cable is good.
I thought of one more:
Check to make sure that the jumpper is set to the user program and not the default Scetion 9 pg 33.
#0047 (ChiefDelphi)
1 other thing
Posted by Raul.
Engineer on team #111, Wildstang, from Rolling Meadows & Wheeling HS and Motorola.
Posted on 1/9/2000 10:21 PM MST
In Reply to: Re: STAMP II not responding to computer posted by Steve Shade on 1/9/2000 8:42 PM MST:
I know this may sound dumb, but it happened to me:
Make sure that you are indeed supplying 5 volts to the board. I had a 9 volt battery regulated to 5 volts, but the battery was actually run down below 5 volts. The LED indictor will shine brightly down to about 2 volts so it can fool you into thinking that your power source is OK.
Raul
#0047 (ChiefDelphi)
Re: Select the right stamp type
Posted by Alan Nickerson.
Engineer on team #157 from Assabet Valley R.T.H.S..
Posted on 1/15/2000 3:05 PM MST
In Reply to: 1 other thing posted by Raul on 1/9/2000 10:21 PM MST:
Make sure you have selected the BS2SX as the stamp mode (Edit->Prefrences->Editor Operation)for the Innovation First controller or the BS2 for the 1998-1999 controller
Alan
[IMG] code is Off
My computer loves Microsoft ARGH!! HELP ME! team222badbrad Chit-Chat 12 29-01-2005 09:17
List of UTC Hartford Teams archiver 2001 3 24-06-2002 01:09
Full list of teams & competitions archiver 2001 14 24-06-2002 00:52
Have a question about the Basic Stamp Chip Boards wes16zeus Programming 3 06-12-2001 08:25
My other computer will not work with this forum! David Kelso CD Forum Support 4 04-06-2001 21:52
