Go to Post Losing, like criticism, is the only thing that makes you improve. - MooreteP [more]
Unread 15-01-2008, 09:29
team1203 4life's Avatar
team1203 4life team1203 4life is offline
President
FRC #1203 (Pandemonium)
team1203 4life is a jewel in the roughteam1203 4life is a jewel in the roughteam1203 4life is a jewel in the rough
Send a message via AIM to team1203 4life
Re: Why don't I ever see robots that steer like a car
Originally Posted by Capt. Quirk View Post
Wouldn't that be an advantage in this competition?
because the turning radius is to large and would put you out of position
p.s sorry if this was already posted didnt read through all of them
Unread 15-01-2008, 09:51
Jherbie53's Avatar
Jherbie53 Jherbie53 is offline
Hoshua The 2nd
AKA: Joshua aka "Hosh"
FRC #0085 (Built On Brains B.O.B.)
Jherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to behold
Send a message via Yahoo to Jherbie53
Like the others have said, it would be hard for you to turn around and go backwards in a quadrant. Other than that, this years game would promote it I think. If you decided not to hurdle the trackball or pick the trackball up off the ground, then you could build a really nice drive train that turns easy and could push the trackball around the track. I don't how easy it would be to build a CAR like drive train,( I'm not that technically inclined in this area ).
The reason why I think most teams don't use it is, like Kevin Sevcik said, you have to do a Y turn to turn around and its so much easier to have a drive train that can spin in a tight radius. Another reason is that it might be harder to build a CAR steering mechanism rather than lining up 6 wheels and running chain to all the wheels from a gearbox.
Unread 15-01-2008, 10:53
1086wulf's Avatar
1086wulf 1086wulf is offline
AKA: Ian
FRC #1086 (1086 Blue Cheese)
1086wulf is an unknown quantity at this point
Car like steering was not really advantageous in the past because the games were more of maneuverability. This year however, since you will be running around the track, I would think if your strategy is to just run around to get points then it would work well. If you are herding it may cause some problems if you lose control and try to get the ball back.
"You sure know how to throw a party. No food, no drinks, and the only babe just left." Dante DMC3
Unread 15-01-2008, 12:39
Kit Gerhart's Avatar
Mentor, coach, whatever--
FRC #0233 ("The Pink Team")
This year, for the first time since I've been involved with FIRST (12 years) we discussed car type steering briefly. For this game it might have an advantage in that you would have better precision when driving through holes in traffic than with tank type drives. The down side, as others have mentioned, is that you can't "turn in place" as with tank drive. Because of it's simplicity, I'm sure most teams will use tank drive this year, but will be practicing some different driving skills than for most previous FIRST games.
Team 1062, The Storm, 2003
Unread 15-01-2008, 12:52
R3P0's Avatar
R3P0 R3P0 is offline
Always InTeNsE!
AKA: Jamie Robinson
FRC #1504 (Desperate Penguins)
R3P0 is a glorious beacon of lightR3P0 is a glorious beacon of lightR3P0 is a glorious beacon of lightR3P0 is a glorious beacon of lightR3P0 is a glorious beacon of lightR3P0 is a glorious beacon of light
Send a message via ICQ to R3P0 Send a message via AIM to R3P0 Send a message via Yahoo to R3P0
Team 1504 is making this kind of steering.
Isn't overdrive NASCAR for robots with a huge ball?
R3P0
Time is irrelevant at the speed of light.
Unread 15-01-2008, 12:57
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
My typical overthink analysis of this question:
Ignoring other aspects of the game, if you want to go just for the absolute minimum lap time, I suspect that an automotive-style drive train and ackerman steering system would be the ticket. In either rear-wheel drive or four-wheel drive form, in principle there should be less frictional losses and smoother direction change control.
One gotcha with this is your un-steered wheels need to compensate for the different driven path length around corners. A differential can lead to sitting still with one driven wheel spinning while drifting (sliding) a solid axle takes more finesse to drive and re-introduces frictional losses, so I'd opt for differential control of the motors driving the wheels (sync'ing them to the steering angle).
In the real world of Overdrive I think all this is moot, because it will be pretty darn hard to get a clear lap to make use of the little bit of extra speed you might have. Besides, us oldtimers recall a certain Evil Machine with six-wheel drive and tank steering that just plain flew around the field a few years back, proving that drive system can be fast, manuverable and push like an irresitable force - without any complicated steering system.
Pete Kieselbach
Unread 15-01-2008, 13:13
deshirider430's Avatar
deshirider430 deshirider430 is offline
AKA: Shan Rammah
FRC #0612 (Chantilly Robotics)
deshirider430 is just really nicedeshirider430 is just really nicedeshirider430 is just really nicedeshirider430 is just really nicedeshirider430 is just really nice
612 (05') http://www.chantillyrobotics.com/pho...?g2_itemId=875
2008 NASA/VCU Chrysler Team Spirit Award
2008 Buckeye KPC&B Entrepreunership
2008 Buckeye Regional Chairman's Award
Unread 15-01-2008, 15:11
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
What I'd like to see is a tractor-style turning mechanism. 3 CIMs on 1 transmission that drives 2 rear wheels from a differential. To turn, all you do is brake the side you want to turn to. Put unpowered omnis on the front and BAM there you go -- seems easy enough right?
GitHub
Unread 15-01-2008, 23:59
Capt. Quirk Capt. Quirk is offline
AKA: Bill Mazzacane
FRC #1704 (Robotic Steelers)
Capt. Quirk will become famous soon enoughCapt. Quirk will become famous soon enough
The easy way around that is to just let your inside wheels freewheel through the corners. The differential and "Steering Brakes" like JesseK suggested would turn wickedly fast. Programming for the turn angle or using a Go-Kart style chassis that lifts 1 wheel and with programming, could drive 3 wheels would be another option.
Nice pictures deshirider430, how did it work?. I was worried that using the window motors would limit how quickly the bot could change directions?
A differential wouldn't be hard to make and I think multiple motors feeding a differential would be a great idea, Especially for the 6 wheel drive "tractor style" drive train. All it would take is steering brakes and then the outside bank would receive full power.
Unread 16-01-2008, 01:40
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
After going through a similar overthink analysis, we came up with a different approach that should beat an automotive-style drive train with Ackerman steering - and arguably almost any other "standard" system. I won't just give it away, but let's just say that it involves reducing the deceleration time required to make the turn at the end of the Lane Divider to the absolute minimum amount of time possible, and constructing the ability to withstand repeated 53-G impacts into the robot.
-dave
Unread 16-01-2008, 01:50
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
-dave
So you decided to go with this, afterall?
2001-2004: Team 100
2006-Present: Team 254
Unread 16-01-2008, 02:14
dlavery's Avatar
Curmudgeon
We will see after the CDR on Saturday. Either way, it is a fun idea (if we don't go with it, it may still be a fun off-season project to prepare for IRI).
-dave
Unread 16-01-2008, 02:22
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Actually, those who were adept at patrolling the area around the rack by driving in arcs last season may discover that that skill directly translates into making smooth gradual turns through the lane dividers with a tank steering setup this season.
Unread 16-01-2008, 02:26
O-H
-dave
Bat-Steer? Holy CO2 grapnels, Batman!
Unread 16-01-2008, 02:55
AKA: Bill Mazzacane
-dave.
By the ball, wall or other robots?
why I don't like this year's game copperhead47 General Forum 40 09-01-2008 08:32
pic: A sight you don't generally want to see Billfred Extra Discussion 8 05-11-2006 23:23
Why I don't like it when politicians visit the QC... Jeremiah Johnson Chit-Chat 4 18-07-2006 15:03
pic: You don't see this often... RoboMadi Extra Discussion 6 03-05-2006 06:24
Can Dean Kamen, inventor of the Segway see why kids like cinnamon toast crunch? Michael Hill Chit-Chat 4 31-03-2006 14:14
