Go to Post Short answer, the GDC has ruled it legal explicitly through Q&A, implicitly through Q&A, and implicitly through the Manual. - EricH [more]
Unread 16-01-2008, 06:49
Tim Skloss's Avatar
Tim Skloss Tim Skloss is offline
Dr. Skloss
FRC #0930
Team Role: Parent
Tim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the rough
Re: Can't mount the gear tooth sensors
Originally Posted by AndyB View Post
I'm curious about this as well. Can a gear tooth sensor work from what seems to be around 3/4" to 1" away from the gear?
No. According to the data sheet the sensor must be 2.5 to 1 millimeter from the gear, and directly facing it.
The only way to mount to the clear cover and reach the 50 tooth gear at the bottom is to use spacers. I tried 3/4 inch spacers, and that was a little too long. Half-inch spacers may not be enough.
In the end we drilled the aluminum plate and mounted with a few plastic washers. Then it worked great. See the pictures above.
FIRST Mentor and Team Leader
C.O.R.E 2062 a NASA, GE Volunteers and Rockwell Automation FRC Team
Unread 16-01-2008, 07:05
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
We ended up basically carrying the holes from the lexan shield over to the aluminum shield and everything works great. Thanks for your help.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Help with the Kit Gear Tooth sensors Keo-san Programming 9 20-02-2007 08:07
dumb question: Where do we get the gear tooth sensors from? waialua359 Programming 6 30-01-2007 22:45
where can we buy hall effect sensors or gear tooth sensors amirjpl Electrical 3 13-02-2006 11:02
Gear Tooth Sensors et1337 Electrical 7 28-01-2006 22:48
Accelerometer vs Gear Tooth Sensors zdeswarte Electrical 4 22-01-2005 15:35
