Go to Post last year I wanted to electrically charge our frame, then cover the whole bot in tape and say it was for insulating purposes. Then I settled down and read the rule book. - russell [more]
Unread 16-01-2008, 09:17
Rapt0r9's Avatar
Rapt0r9 Rapt0r9 is offline
AKA: Tyler
FRC #0747 (Flight Crew)
Rapt0r9 will become famous soon enoughRapt0r9 will become famous soon enough
USB To Serial Converter Issues
I am pretty sure that this may have been addressed before, however, we have been have incredibly long download times using a Belkin USB to Serial Converter. I have read that the download times for other teams have been up to 2 - 3 minutes, but last night when I timed a download it took 40 minutes. We no longer have access to a computer which has a DB-9 port, so this is our only option. The USB ports are USB 2.0 and the Baud Rate was set to 115200. I have no idea why this is happening and have been trouble shooting for the past couple hours. Has this happened to anybody else, or does anybody have a potential solution for our extremely long download times? Thanks.
BS Information Technology - NJIT (2009 - )
Team 869 (2004 - 2008, 2011 -), Team 1811 (2010), Team 869 (2009), Team 613 (2009 - 2010)
"Nothing in this life worth having comes easy."
Unread 16-01-2008, 09:27
kE7JLM's Avatar
kE7JLM kE7JLM is offline
KE7JLM `
AKA: John Harris
FRC #0842 (Falcon Robotics)
Team Role: Driver
kE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to all
Send a message via MSN to kE7JLM
Re: USB To Serial Converter Issues
We had the same problem, use this. http://www.iogear.com/main.php?loc=product&Item=GUC232A
it works great!!
Team 842 Programmer
Pictures at:
http://picasaweb.google.com/KE7JLM
http://picasaweb.google.com/john.h.842
Videos -
http://www.youtube.com/user/KE7JLM
When your not busy with FIRST try NURC
Unread 16-01-2008, 09:55
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Use the vex cable that will net the better results.
If your laptop has PCMCIA that runs like a internal serial port.
Unread 16-01-2008, 13:12
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
When I had my old laptop with a native COM port, downloads used to take a matter of seconds- Now they take about 2-3 minutes with both of these USB to SERIAL convertors I've tried. Is 2-3 minutes for programming normal for you guys?
Alex
Amperage Robotics Team 1225
Site under-going revamp. :/
Unread 16-01-2008, 13:36
Unfortunately, yes. When our programming laptop's serial port got fried a few years ago and we started using a USB converter, the extra time became pretty annoying. We learned to double-check everything before compiling to make sure we got the best value for our download time. Before, we'd been tossing simple changes in and trying them out. Now, we think them through a bit more closely.
Unread 16-01-2008, 15:16
random_guy7531 random_guy7531 is offline
FRC #0118 (Robonauts)
random_guy7531 is an unknown quantity at this point
while ive never had a bad experience with my usb to serial on my laptop, i can say that usually problems can occur when the actual converter is not usb 2.0 compatible. while the computer may have usb 2.0 ports, sometimes the converter is not usb 2.0 compatible (i learned this from the lonestar regional, as another team had the same problem). Our team doesnt use them very often, as the company laptops the mentors have all have db9 ports as do the desktops. Either way, we write so much code that it takes a good 1-2 minutes to load it all even on a db-9 port, so i dont even want to think about using a converter, esp. one that isnt usb2.0.
IFIloader and usb converter does not work jasonpeinko Control System 9 09-01-2008 20:54
Using a USB to 15 pin converter gillejr Control System 7 29-01-2007 20:44
Parallel to serial converter John Gutmann Electrical 8 12-08-2005 12:32
USB to Serial converter for controller Ryan Collings Programming 10 22-01-2005 13:14
USB to Serial Jack Programming 24 23-12-2002 14:21
