Go to Post The question is like asking "Is it better to drive by looking at a map the whole time or by remembering where you want to go and watching the road instead?" - lukevanoort [more]
Unread 16-01-2008, 11:16
tgwalker tgwalker is offline
FRC #2341
tgwalker is an unknown quantity at this point
Welding?
Are teams allowed to weld their robot together?
Unread 16-01-2008, 11:17
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Re: Welding?
yes
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 16-01-2008, 11:18
Ross340 Ross340 is offline
It's all food in the food
AKA: Ross
FRC #0340 (G.R.R.)
Team Role: Driver
Ross340 will become famous soon enoughRoss340 will become famous soon enough
Re: Welding?
Yes sir. 340 has been doing it for years. I learned to weld here and I love it.
Unread 16-01-2008, 12:01
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: Welding?
As everyone else said, yes.
The only word of caution that should be added is that if you break a weld (say on your frame) at a competition, you CAN NOT fix that weld in your pit area, but have to bring it to the FIRST approved machine shop at the event which may or may not be full from other teams using it.
Just something to think about.
Unread 16-01-2008, 16:11
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
Re: Welding?
We had a welded chassis last year and loved it. One thing we did do was figure out how to fix a broken joint without welding in case it happened. It never did (not even when we were knocked off a high ramp) but what we came up with was bringing some oversized square tubing (our chassis was made of 1x1 square aluminum tubing) that could be quickly cut and bolted across the broken area. We did a quick practice run (on some spare tubing) and it only took us about 10 minutes to cut the big tubing to the right size, drill holes and put in bolts. If you want to do something like this remember to make the size of your robot a little bit less and 28" x 38" so you won't break the size rules.
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
Unread 16-01-2008, 16:42
AKA: Ross
FRC #0340 (G.R.R.)
Team Role: Driver
Re: Welding?
Just lay down good welds. Then it won't happen. And if you break a weld at FLR or Championship, Just call me (Ross Temple) down, and I'll fix er' up for you. Assuming I'm not driving
Unread 16-01-2008, 18:08
AdamC's Avatar
AdamC AdamC is offline
Lathemeister
AKA: Batman
FRC #0395 (2Train Robotics)
AdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of light
Send a message via AIM to AdamC
Re: Welding?
As a rule of thumb, we (395) never weld. First of all, we don't have the facilities, tools, or training to do it, and we are also afraid of breaking a weld and being unable to repair it in time. We're much more fond of cutting notches in the chassis and bolting the thing together using pressed nylon inserts.
"The glass is neither half-full or half-empty. It is twice as large as it needs to be."
"Any job worth doing is a job worth dying for."
Unread 16-01-2008, 18:45
BigJ BigJ is online now
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Re: Welding?
1675 builds their robot in a welding shop!
(Well, metal-fab shop.)
We weld a lot of stuff. And yes, last year we had a weld break in atlanta. Did you see the pic in the kickoff intro with the kid yelling and grabbing at the driver's station wall? Yeah, a professional photographer snapped a shot of his face as the 'bot was falling over.
Everything got fixed before our next match, though
I don't know how to weld though, I'm a programmer!
Unread 16-01-2008, 18:53
MDodge27's Avatar
MDodge27 MDodge27 is offline
"O.D."
FRC #2077 (Laser Robotics)
MDodge27 is an unknown quantity at this point
Smile Re: Welding?
our team: Laser Robotics Team 2077 has a sponsorship with the amazing local company Generac. They make all of our parts in aluminum. therefore we never have to weld.
Team 2077 Slogan:Design, Build, Dew.
Unread 16-01-2008, 19:32
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
Re: Welding?
welding works fine if you know how to do it right, just have spares
remember for aluminum go fast and hot (im assuming your using aluminum for weight purposes)
Championship - Delphi "Driving Tomorrows Technology"
Unread 16-01-2008, 20:27
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Welding?
Welding is a great way to build a robot frame. Very strong and lightweight. You would be amazed at the pounds you can save by eliminating all the fasteners and joining hardware. However, an FRC robot frame should really be TIG welded by an experienced professional. Also, issues can arise such as heat affected zones, and warping. If done properly, welds should not break, however you should have a plan to fix it by bolting/etc if you do happen to break one at competition.
Unread 16-01-2008, 20:44
mattotters's Avatar
mattotters mattotters is offline
leadership/fab team
FRC #1228 (A-MERK-IN-INDIANS)
mattotters is an unknown quantity at this point
Send a message via AIM to mattotters
Re: Welding?
People have broken welds? not the metal?
No sleep till the new jersey first robotics regional!
Unread 17-01-2008, 07:07
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Re: Welding?
Team 1501 will have a welded Chrome Moly frame again this year.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 17-01-2008, 08:18
BanksKid's Avatar
BanksKid BanksKid is offline
..as The Circuitrunner.
AKA: Banks, Ethan Banks
FRC #1002 (Circuitrunners)
BanksKid will become famous soon enoughBanksKid will become famous soon enough
Send a message via AIM to BanksKid
Re: Welding?
if your doing aluminium make sure you have someone experianced welding it.....if not youll waste alot of time and material maby even a TIG
"WE HAVE A CAMERA RIGHT NOW!"
R.I.P. SAM
Unread 17-01-2008, 08:44
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: Welding?
We weld a lot of aluminum, and do not profess to be pros.We had a weld break at Detroit last year, but had a spare part. the usual failure is due to heat effected zones loosing their heat treat and using thin section, there is a lot of fatigue cracks (and yes some breaks) in the post season. If you use 6061 T6 and do not post heat treat forget the T6 portion when doing your strength calcs and assume you have annealed 6061. I.E. 40KSI aluminum becomes 8KSI aluminum.
If you don't have a good welder (both machine and person running it), stick to other joint methods. There are a lot of great teams that avoid welding. If you have a good welder (both machine and person) You can do some amazing weight saving. Make sure you make spares of high impact parts because the loads they take may shock you.
ARC Welding Aluminum Simon Strauss Technical Discussion 12 20-09-2006 19:45
Welding with....WATER??? Greg Perkins General Forum 35 01-06-2006 12:00
Student Welding? thecheatdx General Forum 45 02-02-2006 14:08
No welding? Katie Reynolds Rules/Strategy 7 20-02-2003 17:33
WELDING BOOTY BURGLAR OCCRA 2 05-10-2001 21:22
