Go to Post We just need to make engineering an interesting everyday thing, as visible as art exhibits or concerts or football games. - Alan Anderson [more]
Unread 16-01-2008, 08:44
gnormhurst's Avatar
gnormhurst gnormhurst is offline
Norm Hurst
AKA: gnorm
#0381 (The Tornadoes)
gnormhurst will become famous soon enoughgnormhurst will become famous soon enough
after reset, terminal window prints garbage
Here's a question: What does DOWNLOADING do that RESET does not do?
Here's the story:
After I download new code, the code starts running and printf-ing to the terminal window -- everything is fine.
If I press RESET on the RC, the terminal window continues to show output, but it's unreadable -- instead of letters and numbers there are weird symbols and other characters.
The rhythm of the output is unchanged (I only printf() stuff every 20th cycle, so it's about twice a second). But it's unreadable junk -- garbage.
Downloading again (the same code or different) clears up the problem until the next RESET. But that's not a solution, it's just a clue.
What's going on?
I've searched the archives and found someone with the same problem, but there was no answer.
Trenton Tornadoes 381
2004 Philadelphia Regional Winners
2006 Xerox Creativity Award
My corner of the USPTO.
My favorite error message from gcc: main is usually a function
My favorite error message from Windows: There is not enough disk space available to delete this file.
Unread 16-01-2008, 08:59
Re: after reset, terminal window prints garbage
Which serial port code are you using?
Unread 16-01-2008, 11:10
gnormhurst's Avatar
Norm Hurst
AKA: gnorm
I'm using <stdio.h> and not "printf_lib.h". Is that what you meant?
My InterruptHandlerLow() is the usual:
void InterruptHandlerLow ()
	if (PIR1bits.RC1IF && PIE1bits.RC1IE) // rx1 interrupt?
		#ifdef ENABLE_SERIAL_PORT_ONE_RX
		Rx_1_Int_Handler(); // call the rx1 interrupt handler (in serial_ports.c)
		#endif
	else if (PIR3bits.RC2IF && PIE3bits.RC2IE) // rx2 interrupt?
		#ifdef ENABLE_SERIAL_PORT_TWO_RX
		Rx_2_Int_Handler(); // call the rx2 interrupt handler (in serial_ports.c)
		#endif
	else if (PIR1bits.TX1IF && PIE1bits.TX1IE) // tx1 interrupt?
		#ifdef ENABLE_SERIAL_PORT_ONE_TX
		Tx_1_Int_Handler(); // call the tx1 interrupt handler (in serial_ports.c)
		#endif
	else if (PIR3bits.TX2IF && PIE3bits.TX2IE) // tx2 interrupt?
		#ifdef ENABLE_SERIAL_PORT_TWO_TX
		Tx_2_Int_Handler(); // call the tx2 interrupt handler (in serial_ports.c)
		#endif
I'm not sure exactly how the various ENABLE_SERIAL_PORT_xxx_xx macros are set (I don't have a copy of the code with me) -- I'll have to check. But even if all four were enabled, that should not do bad things, should it?
And why should the startup conditions after download be different than after a reset?
Unread 16-01-2008, 12:33
jerry w's Avatar
jerry w jerry w is offline
Free Agent Mentor
no team (Team Krunch)
jerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud of
when downloading code, the baud rate is set by the download control. at the end of the load, the serial port is left at the download rate.
after reset, you must properly set the baud rate in your code. it sounds like the serial port init is not running in your code.
jerry w
Happiest when people tell the truth... However, I am blessed with many friends.
Unread 16-01-2008, 13:09
gnormhurst's Avatar
Norm Hurst
AKA: gnorm
That sounds very likely. I will check it at my next work session (Thursday).
Thanks!
Com Terminal 1 Window Problem. groovy69 Programming 4 25-01-2007 22:58
Terminal Window teh_pwnerer795 Programming 1 02-01-2007 00:21
Terminal Window Idaman323 Programming 0 20-02-2006 19:28
Code Error after reset iplayfast Programming 2 20-02-2006 12:35
Is Terminal Window Evil? Fat Alex Programming 1 20-07-2004 10:57
