Go to Post I think Baker has lost it. - Andy Baker [more]
Unread 16-01-2008, 12:40
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
2007 CIM's in 2008?
Hey, we are planning on using 4 CIM motors this year on our robot, and as of right now we are using the 2007 cims for testing.
We are wondering wether or not we can use these motors when the bot is done, or do we have to buy new ones?? We don't have much money, so if we don't need to buy them then it would be great.
I looked through the rules and can not find anything saying you can't use the 2007 motors, and as far as I can tell they are COT items are they not?
Unread 16-01-2008, 12:52
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Re: 2007 CIM's in 2008?
I know it's in the rules and i am paraphrasing here: you may use parts out of last year's KOP only if they are an exact match to what is in this years KOP and only for spare parts.
In your case, you would have to buy two more to use on your robot but you could use your old ones if the motors died on you. I would read the "robot" section of the rules to double check.
Unread 16-01-2008, 12:57
Kat Kononov's Avatar
Kat Kononov Kat Kononov is offline
AKA: artqny
FRC #2022 (Team IDK)
Kat Kononov is an unknown quantity at this point
Send a message via AIM to Kat Kononov
<R58> Motors, pumps, and, Robot Controllers from previous robots shall not be used in addition to those provided in the 2008 Kit Of Parts. They may be used as direct one-to-one SPARE PARTS for those provided if the provided part fails or is damaged. They can only be used if they are identical to the part being replaced.
<R59> Additional motors specifically permitted on 2008 FRC ROBOTS include:
• All motors, actuators, and servos provided in the 2008 Kit Of Parts,
• HITEC HS-322HD servos,
• FIRST Tech Challenge (FTC) servos (Innovation First part number 276-2162),
• FIRST Tech Challenge (FTC) motors (Innovation First part number 276-2163),
• One or two additional 2-1/2” CIM motors (part #FR801-001 and/or M4-R0062-12 in addition to those provided in the Kit Of Parts. This means that up to four, and no more, 2-1/2” CIM motors can be used on the ROBOT.
I think these are the rules associated with your question.
Unread 16-01-2008, 12:58
Originally Posted by wilsonmw04 View Post
I know it's in the rules and i am paraphrasing here: you may use parts out of last year's KOP only if they are and exact match to what is in this years KOP and only for spare parts.
I think you should ask Q&A. More than one team is affected here. Because the CIMs are custom for FIRST (I think), it would seem like they can't be used, except that they don't change year to year.
Also, if a part (unlimited allowed) is KOP but is also COTS, and you buy it as a COTS, would it count as kit or COTS? I would say COTS.
Unread 16-01-2008, 12:59
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Originally Posted by Kat Kononov View Post
I don't think you can use 2007 CIMs because they're not the same as the 2008 CIMs.
In what way are this year's CIMs different from last year's?
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 16-01-2008, 13:01
AKA: artqny
Last year they was a 3" CIM and two 2.5" CIMs and this year there are only the two 2.5" CIMs.
Unread 16-01-2008, 13:04
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
Last year they were 3" CIMs and now they are 2.5" CIMs.
There was both 3" and 2.5" CIM's last year. . . this year only the 2.5"
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 16-01-2008, 13:10
AKA: artqny
hmm oops never mind. last year there was a 3" CIM and two 2.5" CIMs. This year there are only the two 2.5" CIMs. I'm sorry for confusing everyone.
Unread 16-01-2008, 13:11
GaryVoshol's Avatar
Cogito ergo arbitro
Last year there were 2 sizes of CIMS, this year only 1. You can't use the 3" (the minibike motor) this year because they were not COTS, they were supplied only as part of the kit on a one-time basis. You or anyone else can buy a 2.5" from IFI.
While you could read into <R58> that no motors from previous years can be used except as spares, the text in <R59> says that up to two 2.5" CIM motors may be used in addition to those in the KoP. It doesn't say that these two motors must be newly purchased. (They will have to be treated as purchases in your bill of material accounting.)
(since 2004)
Unread 16-01-2008, 13:12
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
All of the 2.5" CIM's (with the keyed shaft, not the funky splined shaft) are the same p/n, FR801-001. Therefore, the motors are identical and can be used.
We did thorough research on the history of the FR801-001 part number last year. We found that the 2.5" CIM's DID have a shaft change (fully keyed to partially keyed) but the part number stayed the same FR801-001. Therefore, as the rules stated, we were allowed to use them.
The first year of the 2.5" CIM (2002 I believe) had a funky splined shaft that mated up with a sintered bronze adapter gear. Those specific 2.5" CIM motors did not have the FR801-001 p/n on them, and are no longer legal. (Not that I'd ever want to adapt to it again...)
*As always, the answers here on CD are not official, and the only official answers can be found on the Q&A forum. However, I would bet my robot on it that the motors are legal...*
Bengineer
Unread 16-01-2008, 13:22
I took a look a few minutes ago. GDC simply pointed to some of the motor rules without giving a clear answer one way or the other.
I'm with you though, due to precedent. (Admittedly, previous years' rules do not apply this year.)
Unread 16-01-2008, 13:29
AdamHeard's Avatar
Lead Mentor
I'd say, even if the wording makes them illegal. Due to intent of the rule, they are probably legal and the wording will be updated.
Unread 16-01-2008, 14:13
The rules in Rev B
 All motors, actuators, and servos provided in the 2008 Kit Of Parts,
 One or two additional 2-1/2” CIM motors (part #FR801-001 and/or M4-R0062-12 in addition
In the true interpretation of the rules, last year's motors can only be used as spares for the identical motors supplied in the KOP. I highly recommend you ask the question of the Q&A. In my opinion, there is no advantage to your team by using last year's motors to fill out a four motor design and therefore could be allowed. The financial constraint is a valid issue. The GDC is the final say on this.
Unread 16-01-2008, 14:37
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
I'm sure you can use last years 2.5 CIMs this year.
We have to look at the intent of this rule. It is to stop you from using prior year motors that are not in this years kit not from using last years parts that are identical. As long as you account for the costs of the motors.
I am not in anyway connected to the GDC but I'll bet you all dozen donuts that this will be their ruling.
Unread 16-01-2008, 16:30
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
I don't mean to change the subject, but would Sprockets from previous years that came in the KOP count as COTS? (Call me a n00b, but I can't quite remember what a COTS is..)
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Potomac Vex League 2007-2008 Season gblake VEX 4 17-11-2007 21:29
Where to order CIM's Justin M. General Forum 11 11-01-2007 09:27
Big Cim's vs. Small Cim's waialua359 Motors 4 11-02-2006 21:57
New Mission to Mars in 2007-2008 Elgin Clock NASA Discussion 0 03-06-2005 10:25
