Go to Post Six robots no one has ever heard of playing the finals on Einstein field. That's my dream matchup. - Tetraman [more]
Unread 16-01-2008, 00:18
Nathan's Avatar
Nathan Nathan is offline
FRC #1501 (Team T.H.R.U.S.T.)
Nathan has a spectacular aura aboutNathan has a spectacular aura aboutNathan has a spectacular aura about
Gyro Compass
For top secret purposes this year we need a compass. Do to the fact that compass sensors that rely on the Earth's magnetic field are unreliable at best, we are looking for a compass that uses a gyro.
Now I know that such a compass exists, I remember finding one on the Internet but do to momentary stupidity did not bookmark it. I also know that we could "build" this ourselves by using a regular gyro sensor and an interrupt port, but would much rather buy a gyro that does all the math on board it's chip and just returns a 0-359.9 degree value.
Could anyone help me find this elusive chip?
Thanks a lot,
Nathan
Save money with PriceWombat, a shopping comparison and price tracking tool (that I made!).
Check out my hobby electronics business!
My former robotics team: Huntington County 4-H Robotics
Unread 16-01-2008, 00:46
Gboehm Gboehm is offline
FRC #1516 (Grizzlies)
Gboehm is a splendid one to beholdGboehm is a splendid one to beholdGboehm is a splendid one to beholdGboehm is a splendid one to beholdGboehm is a splendid one to beholdGboehm is a splendid one to beholdGboehm is a splendid one to behold
Re: Gyro Compass
Well my experiance flying has taght be a little bit about gyroscopic instruments. Remember that a Directional Gyro is subject to gyroscopic precession. Also a gyro will have to be set prior to each match, also if you compete at more than one event it will have to be set for that new arena.
2005 SVR Highest Rookie Seed
2005 SVR Rookie All Star
2006 WRRF Cal Games Winner
2007 SVR Winner
2007 #7 Alliance Captains Archimedes Divison
"Any sufficiently advanced technology is indistinguishable from Magic." - Arthur C. Clarke
Unread 16-01-2008, 02:17
JohnC's Avatar
JohnC JohnC is offline
my other name is nigel
FRC #0360 (360 Revolution)
JohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the rough
Send a message via AIM to JohnC
Re: Gyro Compass
Or, you can put in your Teleop_Init() some code to initialize the starting position variable of the gyro, and do your calculations based on that.
What place are we at? ... TODAI!
Unread 16-01-2008, 10:17
Nathan's Avatar
Re: Gyro Compass
John, that's what we were planning on doing. We would just initialize it before the match with all the other sensors.
We know there would be some gyroscopic precession, but hopefully it won't be too bad.
Has anybody found one of these yet?
Unread 16-01-2008, 11:04
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
Re: Gyro Compass
97 is trying something similar, though we are going for the DIY approach of matching the kit gyro and a cheap digital compass to get the heading. The problem, if I understand it correctly, is: Compass is unreliable instantaneously because of noise, but good for long-term averaging. Gyro is good for short duration, but long-term it will drift away. So, there is a clever and simple to program filter that will combine the best of both into a clean heading signal.
http://www.chiefdelphi.com/media/papers/2010
You will have to use your imagination to take it from the vertical case, with an accelerometer measuring gravity, to the horizontal case, with a compass measuring heading, but I think it works. Here is a high-level diagram of what we're thinking about:
http://web.mit.edu/first/www/semiOLcontrol.pdf
Some off-board processing, but you could probably do it all on the IFI RC too. There are also other problems like magnetic interference and tilt errors, but maybe these can just be thrown into an offset factor?
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
Unread 16-01-2008, 14:55
Nathan's Avatar
Re: Gyro Compass
Ok, thank you for the info guys.
I was really hoping to find an off the shelf solution so that we didn't have to waste time doing R&D.
Thanks again,
Nathan
Programming a Devantech Magnetic Compass - CMPS03 kE7JLM Programming 7 28-09-2007 08:23
Interfacing a digital compass with the RC Kelly Electrical 14 27-09-2007 19:01
I2C Digital Compass Programming CyberWolf_22 Programming 7 03-01-2005 00:20
Political Compass Joshua May Chit-Chat 11 01-10-2004 22:32
Compass/direction sensor Frank(Aflak) Technical Discussion 10 06-04-2003 09:18
