Go to Post GP isn't just a good idea, it's mathematically optimal. - Jared Russell [more]
Unread 16-01-2008, 14:54
Vanquish Vanquish is offline
Rookie Year: 1980
Vanquish is an unknown quantity at this point
80inch limit
Can you pass through the 80 inch square while your transitioning from your starting stage to your next stage? Like if your claw passes through while you are moving it into your competitive mode
Unread 16-01-2008, 14:57
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: 80inch limit
No, if at any point during the match your robot exceeds an 80" horizontal measurement from one point to another you will receive a penalty.
EDIT: Thanks Eric, I really have to do a better job of grabbing quotes from rules when I respond, then I won't make mistakes like this.
Seems like a question for the Q&A to me.
Unread 16-01-2008, 14:59
EricH EricH is online now
Re: 80inch limit
The rules say nothing about this situation, but...
I would assume, until further official notice, that you can't. After all, if you can break it while moving into playing configuration, then you could probably break it in playing configuration. Better safe than sorry.
Edit: Vikesrock, the relevant rule here is <R16>. <R16> says nothing about transitions into playing configuration, but I would assume those are also covered.
Unread 16-01-2008, 15:00
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Re: 80inch limit
From what i understand, no. you cannot be any longer than 80" at any point during the game. There's another thread dealing with that topic running around here somewhere.
Unread 16-01-2008, 15:01
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Re: 80inch limit
Per R16, you can't exceed 80" in playing configuration, and playing configuration is defined as any configuration you are in while playing, which would appear to include transient configurations.
PLAYING CONFIGURATION - The physical configuration and orientation of the ROBOT while playing
the game (i.e. after the MATCH has started, and the ROBOT has deployed mechanisms, moved away
from the starting location, and/or interacted with the field, GAME PIECES, or other ROBOTS). This
configuration is dynamic, and may change multiple times during the course of a single MATCH
This is also being discussed over here: http://www.chiefdelphi.com/forums/sh...t=61401&page=7
Unread 16-01-2008, 15:39
GaryVoshol's Avatar
Cogito ergo arbitro
Re: 80inch limit
And the best answer from that thread is this one:
Originally Posted by ay2b View Post
The rule can be rephrased as this: if you were to project all points of the robot onto the ground (i.e. a horizontal plane), would there exist any two points which are more than 80 inches apart? If the answer is yes, then the robot is too big.
In other words, look at the "footprint", a term that seems to get lots of mileage these days.
Vanquish references "transistioning" from starting to playing configuration. That is usually associated with what is commonly termed the "flop-bot", one that starts upright and then flops over to drive. Since R16 refers to the playing configuration, it can logically be argued that R16 doesn't apply until you get into the playing configuration.
However, the rest of Vanquish's post doesn't seem to be talking about a flop-bot. If to unfold your arm from its starting configuration you exceed 80" in a horizontal direction, you have come afoul of R16.
Back to the drawing board.
(since 2004)
Unread 16-01-2008, 16:05
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: 80inch limit
I know this has been said before, but it is NOT an 80 sq. square, but an 80 in CYLINDER. If your robot can be placed within that 80 inch cylinder and expand or reposition without breaking the plane of that cylinder at any time, it is legal. That really puts some serious considerations on design, as deployment becomes a consideration.
Unread 16-01-2008, 16:16
Re: 80inch limit
The Q&A removed the cylinder as part of the rule; it's a point-to-point extension. Think of the example of an 80 inch equilateral triangle and an 80 inch diameter circle. The triangle is outside the circle...but it is legal here.
Using a limit switch to limit motion ManicMechanic Programming 16 20-12-2007 00:54
Motor Limit? ForgottenSalad Motors 2 10-01-2006 16:08
Financial Limit R.S. General Forum 2 30-01-2003 15:17
$$ Limit? Stephen Kowski Rules/Strategy 1 08-01-2002 00:01
Post Limit Clark Gilbert CD Forum Support 3 30-07-2001 21:55
