Go to Post Just think outside the box but inside the 28" X 38" X 60" rectangular prism and you may come up with a solution. - Pavan Dave [more]
Unread 16-01-2008, 15:29
nandu10 nandu10 is offline
FRC #2168 (Aluminium Falcons)
nandu10 is an unknown quantity at this point
Re: Help on Programming
On the Digital Output/Input window there are only 4 choices for buttons on the joystick: trigger, aux1, aux2, and thumb. But on the joystick there is a big button between the aux1 and aux2. What is that button called? Where do you program that button in easyc?
Unread 16-01-2008, 16:03
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
I believe this uses p#_aux input. How they do this is they have a different resistor on each of the switch positions and this will cause the number to be slightly different on the Analog Input.
What I would do is do a Print to Screen and move the switch around to see the number changes.
I can post back when I get a chance to test it tonight. Until then I would try doing different print screens of all the values
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 16-01-2008, 18:02
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Thumbs up Re: Help on Programming
You need to use the GetOIAnalog RC block for the hat switch.
Unread 16-01-2008, 22:45
Gamer930's answer is almost completely correct. The joystick "hat" switch is actually connected to the WHEEL input.
Unread 16-01-2008, 22:57
The Lucas's Avatar
Happy Birthday! The Lucas The Lucas is offline
CaMOElot, it is a silly place
This post should give you some idea what values the hat switch returns. I wouldn't use it for anything that needs fine control (like drive) but more like a few (4) buttons like the poster suggests.
Robot Inspector
PLEASE HELP!! Need help programming arm?? amirjpl Programming 12 15-03-2007 15:11
HELP-URGENT PROGRAMMING HELP NEEDED Rohith Surampudi Lego Mindstorm Discussion 1 24-03-2006 23:05
programming help... Shlomi32 Programming 1 08-12-2005 12:28
Programming Help hedgehogger Programming 10 19-02-2004 12:11
help programming aZnXsa1Nt Robotics Education and Curriculum 5 17-12-2002 15:00
