Go to Post To find something they are so passionate about that it oozes into everything they do, and others can't help but want to follow them into this Counter-Culture where good is not good enough, Great is all they strive for. - Kims Robot [more]
Unread 15-01-2008, 19:14
alicen's Avatar
alicen alicen is offline
Zebra Committee
alicen is just really nicealicen is just really nicealicen is just really nicealicen is just really nicealicen is just really nice
Re: Our robot is done!
Don't foget that you must have your flagholder at least 51" high!!
Unread 15-01-2008, 21:58
Brad Voracek Brad Voracek is offline
.999~=1
FRC #0399 (Eagle Robotics)
Brad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of light
Send a message via AIM to Brad Voracek
For the flag holder : there's four inches from the back of the scissor lift to the back of the limitations that the flag will fit on. we had to allocate the room especially.
As for hurdling when we get to the top : the manipulator goes up with the lift, so with a slope and lowering that over the first bar, the ball should roll right over, as long as we position it right.
And most people are correct, we don't plan to want to knock the ball off explicitly, but we do think with the cradle on there we will be able to actuate the scissor lift when we are -underneath- the rails to be able to hit it, it's not something we're designing for yet, and if we are able to do it it's a nice accessory ;P
.999~ (Repeating) is equal to one (1).
Team 399 - Eagle Robotics
Unread 15-01-2008, 22:13
vhcook's Avatar
vhcook vhcook is online now
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
It sounds like you're in great shape I hope your testing goes well.
Unread 15-01-2008, 22:58
Iboshi2's Avatar
Iboshi2 Iboshi2 is offline
AKA: Russel
FRC #0716 (Who'sCTEKS)
Team Role: Operator
Iboshi2 is on a distinguished road
Fantastic design! This allows for a good defensive build and the ability to hurdle! Great! One question- how long does it take to extend the scissorlift to hurdling position?
Team 716 "Dont ever give up!"
Thank you 1124 and 175!
Unread 15-01-2008, 23:02
.999~=1
Good question, haha, I'll get back to you. From preliminary tests with actuators it seems like it will go up rather fast, and we actually may have to run down the pressure from max on these things. We're now using, after more testing today, 2 2 inch bore 12 inch stroke actuators, and we plan to tweak with the psi to get them to run at a reasonable speed. I don't see speed being an issue though, and we're shooting for, I don't want to sound unrealistic as I suppose I don't really know exactly, but maybe around ~6 seconds? Five? I'll let you know as the weeks progress.
Unread 16-01-2008, 16:07
1619Aaron's Avatar
1619Aaron 1619Aaron is offline
FRC #1619
1619Aaron is an unknown quantity at this point
Go with the scissor lift. We did that in 2005 and it worked great. The only problem was our drive base... >< But, we did win the Engineering Inspiration Award with it. First rookie team to ever win it! Anyway, it was awesome.
Unread 16-01-2008, 16:20
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
Just a suggestion/helpful hint.....A better way to slow down the cylinder actuation would be to use adjustable flow controls on the cylinders.
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
Unread 16-01-2008, 16:28
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Here's what will probably end up being our final design for this year, with the chassis and the scissor lift (that's what's under that sheet metal). I know everyone says no scissor lifts, but I think we can do it, and it's one of the more efficient methods we thought of, for what we want to do.
... don't mind the cardboard ball. ;P
Questions?
If that's not a prototype manipulator, you may want to make your manipulator a lot more rigid.
Since the two claws only look like they are about 0.5" diameter aluminum tubing, as soon as another team runs into those, or your driver accidentally runs into the wall at the far end of the playing field, they are going to be bent. There are only so many times you can bend them back until they snap.
Art Dutra IV
世上无难事,只怕有心人.
Unread 16-01-2008, 17:00
boonski's Avatar
boonski boonski is offline
Knight of Alloy
AKA: Matt Taylor
FRC #1535 (Knights of Alloy)
Team Role: Scout
boonski will become famous soon enoughboonski will become famous soon enough
Send a message via MSN to boonski Send a message via Yahoo to boonski
Seems like a good idea. Seriously going for a scissor lift? Good Luck!
What happened to your real trackball? Did it pop?
Unread 16-01-2008, 21:31
.999~=1
Camtunkpa, yeah sorry, that's what I meant... I said psi but I was thinking of those =/.
Oh, that's -definitely- a prototype manipulator. Thanks for the input though, we plan to make that muchh more rigid, probably using ~3/4 or 1 inch square tubing in the end. Heheh.
... and yeah our ball popped. =( oye. new ones tomorrow hopefully.
Unread 16-01-2008, 21:33
Seraph117's Avatar
Seraph117 Seraph117 is offline
A.K.A. Hippie
AKA: Seraph117
FRC #2029 (NeoTech Robotics)
Seraph117 is just really niceSeraph117 is just really niceSeraph117 is just really niceSeraph117 is just really niceSeraph117 is just really nice
Send a message via AIM to Seraph117
if that was really your final design, i would eat my hat
~Seraph117
Question the Answers
Unread 16-01-2008, 22:33
MOE's Avatar
MOE MOE is offline
FRC #0088 (TJ2)
Rookie Year: 1995
MOE is a splendid one to beholdMOE is a splendid one to beholdMOE is a splendid one to beholdMOE is a splendid one to beholdMOE is a splendid one to beholdMOE is a splendid one to beholdMOE is a splendid one to behold
YEP That is right
GOOD LUCK from Team 88 TJ2 and MOE
"Learn skills today with FIRST for tomorrow's JOBS" MOE
Unread 16-01-2008, 23:50
.999~=1
Get ready to eat your hat then. ;P
Seriously though, unless we find a major flaw, this is the -design- we are going to go with. Not the exact mechanisms or anything... but as I said those are the ideas we are running with.
Unread 21-01-2008, 20:19
teammember_342 teammember_342 is offline
Stephen - 342 Design
FRC #0342 (The Burning Magnetos)
Team Role: Student
teammember_342 is an unknown quantity at this point
You will be in the finals for sure!
http://www.youtube.com/watch?v=g2RxEzTawfA
This is one nice robot!
Unread 21-01-2008, 20:21
team1203 4life's Avatar
team1203 4life team1203 4life is offline
President
FRC #1203 (Pandemonium)
team1203 4life is a jewel in the roughteam1203 4life is a jewel in the roughteam1203 4life is a jewel in the rough
Send a message via AIM to team1203 4life
how fast will your robot go in feet per second
pic: 233 robot teaser, yep, theres our robot ; ) ducttapedude Extra Discussion 20 15-02-2007 22:02
pic: This is our robot as of last night. Alot more should get done this week now that things are in place dfukuba Extra Discussion 28 25-01-2007 13:14
pic: 1067's robot (almost done) CD47-Bot Robot Showcase 8 17-02-2004 21:41
IS your robot done? team222badbrad General Forum 21 08-02-2003 18:41
Robot done! archiver 2001 3 24-06-2002 00:23
