Go to Post For all of you thinking three alliances... how big of a pain would it be to have three different bumper colors? - Jon Stratis [more]
Unread 16-01-2008, 16:50
kE7JLM's Avatar
kE7JLM kE7JLM is offline
KE7JLM `
AKA: John Harris
FRC #0842 (Falcon Robotics)
Team Role: Driver
kE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to all
Send a message via MSN to kE7JLM
Power Distribution Block
Do you have to use all the components for the Power Distribution Block? We have only two red blocks in, but the little yellow piece is made to bridge four of the red blocks, do we cut it?
Team 842 Programmer
Pictures at:
http://picasaweb.google.com/KE7JLM
http://picasaweb.google.com/john.h.842
Videos -
http://www.youtube.com/user/KE7JLM
When your not busy with FIRST try NURC
Unread 16-01-2008, 16:56
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Re: Power Distribution Block
You can cut it down if you don't need all the segments in the PDB, but I'd hold off until later in the build season if you can. If you have a late design change and need one of those connection points back, you'd have to buy or scrounge a replacement for the yellow piece.
Unread 16-01-2008, 16:58
Rachel2177's Avatar
Rachel2177 Rachel2177 is offline
AKA: Rachel
FRC #2177 (The Robettes)
Rachel2177 will become famous soon enoughRachel2177 will become famous soon enough
My team is only using two red as well. FIRST gives you four just incase you need it but you don't have to use them all. Tin snips work really well for cutting them bc its a little difficult.
Unread 16-01-2008, 17:12
robotoby35138's Avatar
robotoby35138 robotoby35138 is offline
FRC #1522
robotoby35138 can only hope to improve
i agree with vhcook you might realize later on in the build season that you may need all four of the blocks.
Unread 17-01-2008, 08:48
John,
I agree with the posts above. No one has mentioned the thin blocks yet this year. Those are intended to fully insulate the blocks. If you notice each block is open on one side. When you stack them next to each other they are insulated by the closed side of each block. The thin part is then inserted next to an open side to complete the insulation. The grey blocks are used to stabilize the assembly and hold it all together. Remember to strip you wires 5/8" before insertion. Try it with a single block in you hand. As you insert the wire notice that the wire will push all the way in and stop when the stripped end hits the plastic wall inside the block. When you tighten the mounting screw you will see that the wire is fully clamped and will not pull out.
Most teams will only use one 40 amp breaker panel and one or two smaller panels. Two red blocks are sufficient for that wiring since you can connect wires to either side of the block. However, most teams will use all four of the black blocks if they return high current motor power to the Rockwell block as shown in the Power Distribution Diagram. I recommend this method since it produces the lowest loss and gives the greatest voltage to the RC.
Power Distribution Block Grounding Karma Electrical 15 22-01-2008 07:18
Power Distribution Block.. beemgruem Electrical 21 11-01-2008 08:11
Power distribution Block? Pontchartrain Electrical 3 27-01-2006 07:30
Stinger Fuse Block and Power Distribution Block Don Wright Electrical 2 30-03-2004 10:45
Power Distribution Block DukesElectrical General Forum 0 09-02-2004 23:48
