Go to Post Do not treat Vex and FLL as inferior because they may not get as much exposure as FRC on these boards. Just remember, FLL has seven times more teams than FRC from twenty additional countries. - artdutra04 [more]
Unread 16-01-2008, 17:37
bronxbomber92 bronxbomber92 is offline
FRC #1551 (Grapes of Wrath)
bronxbomber92 is an unknown quantity at this point
Default code will not compile
We migrated to a new computer this year, so I installed v8.00 of MPLAB and v2.40 of the compiler. These are the errors:
Error - Coff file firmat for 'ifi_library.o' is out of date.
Error - Could not build member 'ifi_library.o' in library file 'C:\Code\Proj\deault\FRC_library_8722.lib'
Unread 16-01-2008, 17:44
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
Re: Default code will not compile
a quote for IFI robotics site "You must use MPLAB ver 7.20 and C18 Compiler ver 2.40 (newer versions can not be used)"
Not sure why this is but it still applies
Steve
Unread 16-01-2008, 18:15
mtndurbin mtndurbin is offline
Programming Mentor
mtndurbin is an unknown quantity at this point
There is a version of the base code that will compile with the new compiler
and IDE. It can be found on the Kevin Watson site.
http://www.kevin.org/frc look for the zip file ifi_frc_30.zip.
The libraries are on this site also. We are using the 3.0 compiler successfully.
I am the programming mentor for Team 662 Rocky Mountain Robotics.
Unread 16-01-2008, 19:42
Pulverator's Avatar
Pulverator Pulverator is offline
Pulverator is an unknown quantity at this point
Thanks guys/gals!
I've downgraded to 7.20 and that error is now gone
But... I get a new error.
In user_routines.c, line 193
Error [1203] too few arguments in function call
So, I went to find the Generate_Pwms(), and I see there are 2 prototypes. One or the other is compiled depending on the macro _FRC_BOARD. So, I assume the is being set wrongly - somewhere. Of course, I'm not sure.
Btw, I couldn't open the default code project because the file format of the workspace was incompatible so I created a new project and added the files to that.
Edit - This is bronxbomber92 posting under a teammates account.
Edit 2 - I just tried compiling Kevin's 2.40 beta code ( I could't open the workspace like above, so I made a new workspace again). I get an error saying
could not find file clib.lib
What am I doing wrong!?!? Something must be seriously screwed up...
Unread 16-01-2008, 22:30
Nothing drastically wrong.
In the first case _FRC_BOARD was used to switch between the FRC and the old Edu controller. The macro used to be defined in MPLAB build options. You can add it under the complier tab or just add "#define _FRC_BOARD" to the code before it gets referenced.
In the second case when you built your new project you didn't set the path where MPLAB is to look for the libraries (mcc18/lib). Also under build options.
Unread 18-01-2008, 16:11
Thanks. I did add mcc18\lib to my include path before, but it then gave me another linking error:
Error - processor types do not agree across all input files.
What shall I do next? That error suggest that possibly I building for the wrong PIC architecture?
Unread 18-01-2008, 16:46
I fixed the problem!! The problem was that the old 8522 linker scripts were still in the project and I believed those were being used instead.
Unread 18-01-2008, 18:44
I hate when that happens...
Code Won't Compile in MPLab with WPILib Inverted Programming 1 20-02-2007 22:12
Do not know where to get default code ZookieWookie Programming 4 13-02-2007 17:23
CMUcam default code not responding Kyveck Programming 29 26-01-2006 16:25
2005 default code won't compile Robby Programming 22 04-02-2005 18:21
Can't Compile the Default Code pressurex1 Programming 4 25-01-2004 20:26
