Go to Post They see us come into school looking like zombies, and they know that some people start smelling like chain lube and such...but for the most part, they don't realize that for a lot of us, there is a deep commitment to our team that we do a very large amount of work for that team. - JakeGallagher [more]
Unread 16-01-2008, 11:39
Japper's Avatar
Japper Japper is offline
FRC #3692 (RocknRobots)
Japper has a spectacular aura aboutJapper has a spectacular aura about
IR control question
To avoid all of the hassles of dealing with robot placement and line of sight of the IR while in Hybrid mode, is it possible to create an IR receiver that plugs into the OI (under its own power) so that the robo-coach can just send the IR commands to the OI instead of an IR receiver mounted on the robot and connected to the RC or are the ports on the OI totally locked out during autonomous mode???
Just a thought...
Unread 16-01-2008, 11:49
Re: IR control question
Originally Posted by Japper View Post
...or are the ports on the OI totally locked out during autonomous mode???
The OI data received by the robot while in autonomous mode is set to "all joysticks centered, no buttons pressed". Control from the OI is not possible until teleoperated mode begins.
Unread 16-01-2008, 13:06
Japper's Avatar
What other options exist for using a omni-directional IR board in place of the one supplied in the kit of parts?
Anyone have any suggestions for something that would be dependable?
I don't have a warm and fuzzy feeling about the IR board supplied...
thanks
Unread 16-01-2008, 18:16
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
Any signaling device is allowed, as long as it complies with <R65> and <R69>. (Well, obviously it has to comply with all the rules, but those in particular have to do with the signaling device.)
Originally Posted by <R65>
Active SIGNALING DEVICES shall:
use visible light, infrared communications, or sound as the transmission method – no other form of electro-magnetic radiation is permitted
If you don't like the IR boards from the kit, you could use different IR boards, or something in visible light (CMUcam?) or something using sound (voice recognition and a robocoach who yells really loudly? Actually that's probably not allowed, because the robocoach is not a "device". But you could have 4 prerecorded sounds, and a device that plays each sound based on which button is pressed.)
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
custom control programming question... herocreator Programming 4 03-07-2007 12:54
Max Control Board Size Question Dermot_135 Control System 5 07-02-2006 22:12
PID control loop/Encoder question Zee Programming 18 30-01-2004 23:14
PBASIC/control system question archiver 2001 1 24-06-2002 00:33
Control Station Fabrication Question... Jim Meyer OCCRA 1 25-09-2001 05:15
