Go to Post And then I learned how to use the lathe...long story short, I ditched my plans to become a music major and became an engineering student. - Karibou [more]
Unread 16-01-2008, 20:18
potatoarecool potatoarecool is offline
FRC #2204
potatoarecool is an unknown quantity at this point
Chassis weight
Hey guys, I was wondering how heavy a robot would be if it was only made of parts from the kit, with nothing but the electronics, 2 motors, wheels and battery. Did anyone check for this? Thanks.
Unread 16-01-2008, 20:26
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Re: Chassis weight
We did that, sort of. We used a 6-WD with two sets of chains on each side. Without the battery it weighted ~47 lbs. With just the parts in the KOP i bet it's closer to 40 lbs.
Unread 16-01-2008, 23:27
wilsonmw04's Avatar
Coach
Re: Chassis weight
Originally Posted by Zyik View Post
Ours is 13 pounds
I find that hard to believe when the frame itself is 17 lbs if you use every piece. heck the Transmissions + CIM's are close to 6 lbs each.
Unread 16-01-2008, 23:30
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
Re: Chassis weight
Our chassis (non-kitbot, fully custom) with no transmissions or anything is 17lbs. With transmissions and two CIMs total it feels much closer to 35lbs.
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 17-01-2008, 09:44
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Re: Chassis weight
We weighed ours with a chassis, 4 wheels, 2 sprockets, 2 gearboxes, and no electronics and it came out around 26 lbs. No battery, only 2 cims. So factor in battery weight and whatever the weight of the electronics panel would be and it probably will run up to around 45 lbs.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 17-01-2008, 10:35
Clifford Clifford is offline
AKA: Clifford Harrison
FRC #2658
Clifford is an unknown quantity at this point
Re: Chassis weight
If you're thinking about what your robot will weigh fully built, remember that the weight of the battery is not included in your total weight at inspection.
Clifford Harrison, Alumni & Mentor
FRC Teams 2658 & 3749
FTC Team 5135
Unread 17-01-2008, 10:40
beemgruem's Avatar
beemgruem beemgruem is offline
AKA: Begüm
FRC #2905 (Sultans of Turkey)
beemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to behold
Re: Chassis weight
Ours is with battery, electronics board, 2 normal 2 small wheels, 2 gearboxes, I don't remember the sprockets. It is 46 Ibs.
Begüm
Unread 17-01-2008, 10:46
Aren_Hill's Avatar
Build Nifty Things
Re: Chassis weight
We finished our frame yesterday at 11.5 lbs
A guy who likes robots.
Unread 17-01-2008, 11:10
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: Chassis weight
Our completely finished uber beefy drivetrain with motors and electronics is right around 50lbs
Mentor 2415
Unread 17-01-2008, 13:36
midway78224 midway78224 is offline
AKA: Rudy
FRC #5572 (Rosbots)
midway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to behold
Send a message via Yahoo to midway78224
Re: Chassis weight
our drivetrain when we finish it was at 55 lbs that was with electronics, supershifters, six wheels, etc....
[size="1"]
2004-2008 '11 457 Greasemonkeys
2012-2013 3997 Screaming Chickens
2014 3614 The Love Machine
2015-Present Rosbots
Unread 17-01-2008, 13:44
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Chassis weight
Our frame is 10.75 lbs.
The complete, operational drive train, save 12V battery, is 35 lbs.
--Madison--
...down at the Ozdust!
Unread 17-01-2008, 14:15
AdamHeard's Avatar
Lead Mentor
Re: Chassis weight
I'm not sure why zyik deleted her post; It was true. Our frame really is 12 pounds. We use extruded aluminum, not the kit frame.
Unread 17-01-2008, 14:20
AKA: Sean
Re: Chassis weight
Ok so I went back and looked at our frame and our frame without anything weighs 20.9lbs. It is made out of custom aluminum plate and standoffs. This is also without any lightening patterns so that the machine shop wouldn't hate us too much haha.
Mentor 2415
Unread 17-01-2008, 14:38
Re: Chassis weight
potatoarecool started this thread by asking how heavy a chassis made only from material from the Kit of Parts would be.
Unread 17-01-2008, 14:42
AdamHeard's Avatar
Lead Mentor
Re: Chassis weight
I completely missed that.... My apologies.
In 2005 when 294 used the KOP frame we saved 1 pound or so removing bits here and there; I've also heard rivets instead of bolts saves a lot of weight.
Weight? Estmate weight? Arkorobotics General Forum 21 29-01-2007 17:34
Wait...weight...weight!!!! Greg Perkins General Forum 3 22-02-2006 07:42
Drive-train / chassis weight Andrew Schuetze Technical Discussion 19 07-02-2006 16:51
pic: (447) Chassis Weight + Appendages rufu5 Robot Showcase 6 09-02-2005 17:55
chassis weight ?! groves General Forum 49 27-01-2003 17:36
