Go to Post Anyways, before we all get worked up over this setup, let's wait and see what details emerge. It can't be as bad as everyone is making it seem. - Karthik [more]
Unread 15-01-2008, 16:46
iwin2000 iwin2000 is offline
iwin2000 has a spectacular aura aboutiwin2000 has a spectacular aura about
Help on Programming
How do you program a button on the joystick in easy C
Unread 15-01-2008, 17:22
SgtMillhouse648's Avatar
SgtMillhouse648 SgtMillhouse648 is offline
AKA: Malhon Godwin
FRC #0648 (QC Elite)
SgtMillhouse648 has a spectacular aura aboutSgtMillhouse648 has a spectacular aura about
Send a message via MSN to SgtMillhouse648
Re: Help on Programming
If I'm remembering right, under the input section, there should be something about OI input or something like that. It should have an option for the switches from the joystick. You should then be able to then retrieve that switch (digital input) to a variable and do what ever you want with it then.
Good Luck
Malhon
Midwest Regional-
Regional Finalists with 1000 and 447
Rockwell Automation Inspiration in Control Award
Regional Woodie Flowers - Ed Wegscheid
Unread 15-01-2008, 17:24
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
In the left window, under "RC Control", there's a "Digital OI Input" block. Let me know if you need more help than that.
JBot
Aren't signatures a bit outdated?
Unread 16-01-2008, 15:29
nandu10 nandu10 is offline
FRC #2168 (Aluminium Falcons)
nandu10 is an unknown quantity at this point
On the Digital Output/Input window there are only 4 choices for buttons on the joystick: trigger, aux1, aux2, and thumb. But on the joystick there is a big button between the aux1 and aux2. What is that button called? Where do you program that button in easyc?
Unread 16-01-2008, 16:03
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
I believe this uses p#_aux input. How they do this is they have a different resistor on each of the switch positions and this will cause the number to be slightly different on the Analog Input.
What I would do is do a Print to Screen and move the switch around to see the number changes.
I can post back when I get a chance to test it tonight. Until then I would try doing different print screens of all the values
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 16-01-2008, 18:02
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Thumbs up Re: Help on Programming
You need to use the GetOIAnalog RC block for the hat switch.
Unread 16-01-2008, 22:45
Gamer930's answer is almost completely correct. The joystick "hat" switch is actually connected to the WHEEL input.
Unread 16-01-2008, 22:57
The Lucas's Avatar
CaMOElot, it is a silly place
This post should give you some idea what values the hat switch returns. I wouldn't use it for anything that needs fine control (like drive) but more like a few (4) buttons like the poster suggests.
Robot Inspector
PLEASE HELP!! Need help programming arm?? amirjpl Programming 12 15-03-2007 15:11
HELP-URGENT PROGRAMMING HELP NEEDED Rohith Surampudi Lego Mindstorm Discussion 1 24-03-2006 23:05
programming help... Shlomi32 Programming 1 08-12-2005 12:28
Programming Help hedgehogger Programming 10 19-02-2004 12:11
help programming aZnXsa1Nt Robotics Education and Curriculum 5 17-12-2002 15:00
