Go to Post I am sad that the Patriots lost, and I am happy for both teams that won...but I am even more thrilled that for the next two weeks robot building in the midwest comes to a standstill. ;) - Jessica Boucher [more]
Unread 16-01-2008, 23:54
Re: Where to connect the backup battery charger
It's a custom circuit. It has to be powered from a 20A circuit breaker.
To address the problem with back-feeding the rest of the robot, just add another 1N5820TR diode in series with the power input. You might still see a small issue with the backup battery draining (slowly) through the charger circuit itself when the robot is powered off, but it will no longer try to run all the Victors.
Alternate Backup Battery Charger Phalanx Electrical 5 24-02-2007 14:51
Powering the cam without a backup battery Uberbots Programming 11 27-01-2006 10:00
Problem with the battery charger Lightposter Electrical 4 19-01-2006 10:39
Battery Charger for long term battery care DougHogg Kit & Additional Hardware 0 08-02-2003 15:25
how do u connect the battery to the robot interface? chrisw Technical Discussion 1 10-01-2002 16:41
