Go to Post If poker is a sport, robotics is definitely a sport. - EricH [more]
Unread 17-01-2008, 03:25
laultima laultima is offline
FRC #1458 (Danvillans)
laultima is on a distinguished road
Send a message via AIM to laultima
Re: FRC Robot Controller/Speed Controller
Originally Posted by RoarRoar View Post
Hello
Can I connect a Digital compass to the FRC Robot Controller,how do this work,if this is possible.
Ive never used a compass on a bot before, but from my Costal Nav knowledge i wouldnt recommend it. All compasses are influenced by two things: variation and deviation. Variation is the difference from true north(north pole) to magnetic north(currently located somewhere in northern Canada), which varies over a few mile distance, depending on your angle to magnetic north. Your biggest worry is going to be the deviation. Compasses use magnets (no surprises (except fluxgates but now were getting technical)) to find magnetic north, and are strongly influenced by metal in the area. So if your next to the admin table and all their fancy electronics creating magnetic fields, youre going to get a different bearing then you would on the stands-side of the field. Deviation will even differ depending on what direction your bot is pointing, in fact all Coast Guard facilities (boats) have to have deviation tables onboard to calculate for any heading.
So if you want accuracy, go for gyros. Much better accuracy for a bot, unless you like doing compass-magnetic-true calculations everytime you turn.
2007 Davis/Sacramento Regional Winner (100, 997, 1458)
2008 Davis/Sacramento Regional Gracious Professionalism Award Winner
What is the FRC Robot Controller Power Consumption amateurrobotguy Electrical 4 02-03-2006 00:23
Speed controllers won't communicate w/robot controller steven114 Control System 12 03-02-2005 21:26
Speed controllers won't communicate w/robot controller steven114 Electrical 12 03-02-2005 21:26
wich fuse should i use for the FRC Robot Controller? or yaniv Electrical 3 18-01-2005 14:50
2003's FRC Robot Controller ahmed Programming 7 18-12-2003 22:43
