Go to Post If it reads MINUS voltage, the power is reversed (and this is bad). - DonRotolo [more]
Unread 17-01-2008, 10:50
sircedric4's Avatar
sircedric4 sircedric4 is offline
AKA: Darren
no team (The SS Prometheus)
sircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond repute
SMC Solenoid Vendor?
We are wanting to use several single solenoid valves on our robot this year, but I am having a hard time finding more of the SMC single solenoids to purchase. (I prefer these over the FESTO ones)
A search on this board mentioned Motion Industries, but when I check there website they don't have the SY3140-6H-S solenoid as the part number is listed in the KOP checklist.
I have done extensive searching this morning and can't find a vendor for this part. I do find similar parts such as the SY3140-LOZ-S, which says it's a 12V solenoid and the picture looks similar to the KOP solenoid. My question is:
Where can I purchase more of these KOP solenoids, and if they're not available what would be an acceptable equivalent?
I can't imagine I'm the only person having this problem this year, so has anyone else already solved this problem? Thanks.
Unread 17-01-2008, 11:30
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Re: SMC Solenoid Vendor?
Seeing as how it's an SMC Solenoid valve, I started with the SMC Corporation website. SMC Corporation
Following their product descriptions, I found this page which lets you configure the exact solenoid valve you want. By choosing the correct options, I was able to recreate the SY3140-6H-S part number supplied in the kit of parts.
SMC probably has a distribution network, so you may be able to find a local distributor of their products. Armed with that part number, I think you'll find what you're looking for. Hope this helps.
Bengineer
Help with the SMC SOlenoid FRC1710 Pneumatics 5 13-02-2007 13:22
SMC Double Solenoid Screw Sscamatt Pneumatics 0 12-02-2005 01:24
Need instructions for SMC Single/Double solenoid WHou Pneumatics 5 29-01-2005 08:17
SMC Double Solenoid Valve Assembly Dave Kempskie Pneumatics 0 29-01-2003 13:34
Single Solenoid Valve SMC Chubtoad Technical Discussion 3 20-01-2002 15:16
