Re: Arm Design Projects-help
Greetings!
I'm not quite sure I understand the question, but if you're looking for an arm simulation you may find this to be useful: http://fixermark.googlepages.com/ArmSimulator.zip It's a simulator I crafted recently that uses Panda3D (which you can get at http://www.panda3d.org) to render a simple one-joint arm with a PID controller. You can modify the length and mass of the arm. This simulator was designed to teach programming concepts, so it isn't hugely accurate from a mechanical engineering standpoint. But if you're looking for a place to start, this might be useful. Best of luck! -Mark |
| Rage Arm Design | TriggsJr | General Forum | 0 | 03-03-2005 10:40 |
| arm design | Zippiot | Technical Discussion | 32 | 27-01-2005 02:56 |
| pic: arm design | Stephen P | Extra Discussion | 17 | 17-01-2005 13:53 |
| Telescopic Arm and grabber design help | M. Hicken | Technical Discussion | 13 | 17-01-2005 12:56 |
| Arm design - rotation mechanism? | n0cturnalxb | Technical Discussion | 6 | 16-01-2005 18:28 |
