Go to Post "Things should be as simple as possible, but not simpler" - Albert Einstein - Edward Debler [more]
Unread 17-01-2008, 14:09
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: Chassis weight
I think we maybe have flipped 3 times in our 3 years and that was all in our first season, but a lot of that is because of the beef in our drivetrains. Now we do go a little overboard sometimes (last year) but it has good results.
Mentor 2415
Unread 17-01-2008, 14:13
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: Chassis weight
Originally Posted by M. Krass View Post
We make everything as light as possible. Adding weight later is much easier than taking it off. In the ten years that I've been with FIRST, I've had a robot tip over twice.
... thinking back fondly to the year we actually had to bolt a 27-pound block of lead on to our robot as ballast.
Too bad FIRST does not still include the "Featherweight In The Finals" award. That was a great incentive!
-dave
Unread 17-01-2008, 14:15
AdamHeard's Avatar
Lead Mentor
Re: Chassis weight
Originally Posted by wilsonmw04 View Post
I find that hard to believe when the frame itself is 17 lbs if you use every piece. heck the Transmissions + CIM's are close to 6 lbs each.
I'm not sure why zyik deleted her post; It was true. Our frame really is 12 pounds. We use extruded aluminum, not the kit frame.
Unread 17-01-2008, 14:20
AKA: Sean
Re: Chassis weight
Ok so I went back and looked at our frame and our frame without anything weighs 20.9lbs. It is made out of custom aluminum plate and standoffs. This is also without any lightening patterns so that the machine shop wouldn't hate us too much haha.
Mentor 2415
Unread 17-01-2008, 14:38
Re: Chassis weight
potatoarecool started this thread by asking how heavy a chassis made only from material from the Kit of Parts would be.
Unread 17-01-2008, 14:42
AdamHeard's Avatar
Lead Mentor
Re: Chassis weight
I completely missed that.... My apologies.
In 2005 when 294 used the KOP frame we saved 1 pound or so removing bits here and there; I've also heard rivets instead of bolts saves a lot of weight.
Unread 17-01-2008, 14:43
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Chassis weight
What is this chassis thing of which teams speak? It seems to be an object which you are able to weigh? I can't find one in our shop yet.
(since 2004)
Unread 17-01-2008, 15:06
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Chassis weight
Can somebody who has done this with the KOP chassis give some idea as to the actual weight savings?
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 19-01-2008, 15:32
Sam2197's Avatar
Sam2197 Sam2197 is offline
FRC #2197 (Las Pumas)
Team Role: Driver
Sam2197 will become famous soon enough
Re: Chassis weight
our frame without anything on it weighed 43 pounds we are gonna deffinately be cutting it close this year
Unread 19-01-2008, 23:24
Dick Linn's Avatar
no team (Synergy)
Re: Chassis weight
A chassis normally starts as a sophisticated structure fabricated from Unobtanium, which is quite difficult to see or weigh. Strong, but very flexible and difficult to grasp. Due to design changes and production difficulties in the normal FIRST shop, later iterations usually form out of aluminum, plywood, or other things you've been tripping over, depending on your budget. Near the end of the build period, portions of the chassis usually appear on the floor in the form of chips or sawdust, due to a process called "lightening". This is not to be confused with the phenomenon called "lightning", which is a part of the electrical and control subsystem that occasionally leaks out.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Weight? Estmate weight? Arkorobotics General Forum 21 29-01-2007 17:34
Wait...weight...weight!!!! Greg Perkins General Forum 3 22-02-2006 07:42
Drive-train / chassis weight Andrew Schuetze Technical Discussion 19 07-02-2006 16:51
pic: (447) Chassis Weight + Appendages rufu5 Robot Showcase 6 09-02-2005 17:55
chassis weight ?! groves General Forum 49 27-01-2003 17:36
