Re: Bumpy Ride with AM's 8" Mecanum wheels?
go to www.team357.com and http://www.airtrax.com/ and look for the reference to their MIT/Inventeam project.
Airtrax is the "world leader in omni directional technology." Check it out.......their whell chair is prett neat and patented and going onto production (the last time I talked to the team leadership) |
The 8" AM mecanum approximates the ideal roller shape with a few rubber cylinders; on the other hand, the 6" actually has a curved roller. Although I have no first-hand experience to back it up, I think the 6" will give you a smoother ride. I don't think the difference is worth another $300 though... just use locking nuts with the nylon inserts on your robot and tighten them and your electrical connections after every match and you should be fine.
There IS one gotcha....
The wheels are normally bumpy because the shift of ground contact from one roller to the next is not always smooth. As long as the rollers are at a 45 degree angle then everything should be good except.... There is only one wheel configuration that will work and give you all functions. ( I know they refer to them as "Right" and "Left" but that's not necessarily the side they go on.) looking down FROM on TOP...look at the top rollers and then look at the roller bolts. They should make an "X" pattern like this: \ / / \ If you don't have this configuration, you can drive forward, backwards, left and right BUT you'll have a terrible time trying to rotate and that will be really bouncy. My two cents Steve |
you probably drove this around on tile surfaces. The carpet makes a HUGE difference! Get some carpet and the bricks and it should be fine. The wheels will bounce a bit naturally but should not be that bad. My team used 3 inch omni's our 1st year and it bounced a bit, but was fine.
We've put together out 8" mecanum bot also, and it vibrates a lot too. We are considering putting electronics and such on a 3/8" sorbothane pads to absorb shock. Do you guys think this would help?
We used the 8" A.M. mecanums last year, it was definitely a bumpy ride even with a 110 lb. robot. This year we're using the 6" A.M. mecanums and the ride quality is significantly better.
That said, we simply checked the tightness of the structural fasteners between every match last year and had no problems due to the vibration [not many problems at all - but that's both luck, and a different thread topic]. Use loctite and nylock nuts where you can, and check the other bolts frequently and you should be able to cope just fine with the vibration. Another thing we noticed was that after hard use, the 8" wheels wore-in some, i.e. the hard corners on the rollers wore off to a rounder profile. It isn't perfect (still vibrates significantly) but they do wear-in after a while. |
#7
When designing any mechanum drive it is important to account for vibrations. Our team used the 6" wheels on an offseason robot and have to give the robot a suspension system for proper driving. Short of that there is really not too much that can be done other than tightening down your bolts and hoping for the best.
| Assistance with Mecanum Wheels | CollmandosGrl | General Forum | 8 | 14-01-2008 17:42 |
| Mecanum wheels | akash155 | General Forum | 12 | 20-02-2007 22:15 |
| Mecanum Wheels | Calvin_1631 | Motors | 7 | 09-02-2007 13:29 |
| Friction coefficients for Omni wheels and Mecanum wheels from AndyMark | Andy Baker | Technical Discussion | 11 | 16-12-2006 19:40 |
| Teams With Mecanum Wheels | Foss@Team176 | Technical Discussion | 15 | 06-10-2005 09:38 |
