Go to Post this thread made crave bacon so badly that I am now, as I write this, cooking 2 pounds of it. :o - gvarndell [more]
Unread 17-01-2008, 15:35
batterybox batterybox is offline
FRC #1728
batterybox is an unknown quantity at this point
bumper question
How stringent will the inspectors be in regards to the thickness of the bumpers?
I've been looking around for 2.5'' pool noodles and I am having a hard time finding a noodle of that size.
I've found some that specify a range for the diameter...2.5-2.75, etc., but cannot find one stating the diameter is 2.5".
Thanks
Unread 17-01-2008, 15:40
Deep Dark's Avatar
Deep Dark Deep Dark is offline
AKA: Dave Woods
FRC #2506 (Saber Robotics)
Deep Dark is on a distinguished road
Send a message via AIM to Deep Dark
Re: bumper question
Usually they're not too bad, provided you construct it the same way and it still obeys the weight limit.
If they're too big, it's easier than if they're smaller. You could take aluminum tubing and fit it down the hole in the center of the pool noodle, stick it in the lathe, then gently shave some off with sandpaper. apply heat after this though, with a heat gun or similar device, just enough to sort of "reseal" the tube. Don't heat it too much though.
I hope that helps.
Dave Woods
Mechanical Engineer - Rexnord Conveying Equipment (New Product Development)
Alumni - Milwaukee School of Engineering (W-11
May '07 - present: Mentor/Co-Lead - F.R.C. Team 2506 Saber Robotics
May '06 - May '07: Mentor - F.R.C. Team 537 Charger Robotics
May '02 - May '06: Student - F.R.C. Team 537 Charger Robotics
Unread 17-01-2008, 15:43
AdamHeard's Avatar
Lead Mentor
Re: bumper question
I very highly doubt pool noodles are high tolerance products and inspectors would even notice, or care if they did, noodles being 1/4" bigger. There really isn't any inherent advantage from that.
Unread 17-01-2008, 15:48
Jaden117's Avatar
Jaden117 Jaden117 is offline
FTC #0354
Jaden117 is an unknown quantity at this point
Re: bumper question
Do you really need bumpers on the robot
Unread 17-01-2008, 15:50
Re: bumper question
They are required per <R08>.
GaryVoshol's Avatar
Cogito ergo arbitro
Re: bumper question
Only if you want to play the game this year. See <R08>.
(since 2004)
Bumper Sensor Question diaperrash89 Programming 3 26-10-2007 06:48
Bumper Question - More like Pool Noodle bLuEpHoEnIx Technical Discussion 5 12-02-2007 21:33
bumper question math4origami Rules/Strategy 4 16-01-2007 14:47
Question about programing the bumper sensors itsme Programming 9 10-12-2006 18:03
Bumper or No? WebWader125 Technical Discussion 19 11-01-2006 01:28
