Go to Post Figure out where you have to start and what end result you want, from there, all you have to fill in is the middle. - Beth Sweet [more]
Unread 17-01-2008, 16:36
Kilroy0846 Kilroy0846 is offline
FRC #2139
Kilroy0846 is an unknown quantity at this point
Omni Wheel
Our team recently purchased 6" Aluminum Omni wheels from Andy Mark. I also got the "press fit" 1/2" ID bearings that are recommended for the wheels. When they said press fit I figured heating up the wheels so the bearing would slide in, then cooling it down to get a tight fit. Contrary to my assumption, the bearings slide right in and out of the holes. I was wondering if any other teams had this problem and how you solved it. Or if there is a standard way to solve this problem that I haven't found on the forums yet
Thanks
pic: Poor Man's Omni Wheel Sean Schuff Extra Discussion 11 24-01-2006 22:48
omni wheel instead of mecanum wheels Leav Technical Discussion 4 15-01-2006 18:53
Omni-Wheel Design fightoplankton Technical Discussion 7 08-01-2006 23:49
pic: Dual omni-wheel Richard Wallace Extra Discussion 17 05-12-2005 10:38
Omni wheel supplier JamesBrown Technical Discussion 5 25-02-2005 13:27
