Go to Post So let me get this straight. We'll have 6 hours to re-build an entirely new robot that took us 6 weeks originally to make. - [more]
Unread 17-01-2008, 16:55
Pneumaticsman's Avatar
Pneumaticsman Pneumaticsman is offline
AKA: Mitch guzman
FRC #1566 (Ammoknights)
Pneumaticsman will become famous soon enoughPneumaticsman will become famous soon enough
Send a message via MSN to Pneumaticsman
Smile Battery
Hey, does the battery have to be mounted vertically, or can it be mounted horizontally, or whichever we choose?
Thanks
Unread 17-01-2008, 17:00
MiniNerd24's Avatar
MiniNerd24 MiniNerd24 is offline
Are you going to eat that?
FRC #2039 (Rockford Robotics)
MiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the rough
Re: Battery
I don't think it matters to the judges (or inspectors), so just fit it in with your robot design and you'll be fine.
The system is down.
Rockford Robotics 2039: Think outside the bots.
Unread 17-01-2008, 17:02
Zultraranger Zultraranger is offline
FRC #0870
Zultraranger will become famous soon enoughZultraranger will become famous soon enough
Re: Battery
Keep in mind there is a strategy on the location of the battery.
Unread 17-01-2008, 17:09
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Battery
Either orientation of the battery is fine both from a rule standpoint and from a safety standpoint. A few things to keep in mind when designing your battery mount are:
1. Make sure the battery is completely insulated from the chassis/frame at all times.
2. Make sure the battery is mounted securely so that it will not come off during the heat of competition.
3. Make sure that your battery is easily removed for changing/charging.
4. It is not recommended (and may not pass inspection) to mount the battery upside down (terminals pointing towards the floor).
Also, always charge the battery in an upright position.
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: Battery
As long as the battery is secure, it should be fine.
Unread 18-01-2008, 08:47
EricVicenti EricVicenti is offline
FRC #0008 (Paly Robotics)
EricVicenti has a spectacular aura aboutEricVicenti has a spectacular aura aboutEricVicenti has a spectacular aura about
Re: Battery
Could you further explain #1 please?
Thanks
Unread 18-01-2008, 09:28
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Re: Battery
Thanks
Make sure you mount the battery so that the terminal connections do not make contact with any part of the frame, or any other metal assembly on your robot. This could cause current to flow through your frame and cause injury or damage to the electronic components of your control system.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 18-01-2008, 09:34
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Battery
it would be nice if the battery cables are not anywhere near metal parts, if you can make that happen. Lexan (polycarbonate sheet) is a great material for building battery mounting stuff, and a wide nylon strap with a plastic buckle is a nice easy quick way to secure the battery into a box, as long as the box holds the battery securely so it cannot move sideways. If you do run the battery cables along a metal surface, it would be nice to secure them to it with some type of cable clamp.
(in this picture the battery box is made of Lexan, which is painted black, normally it's clear)
Unread 18-01-2008, 10:36
Re: Battery
Jim,
The battery may be used in any orientation. Terminals up or on the side is preferred. We have used the battery in the suppine or laid down position in the past. When charging the terminals should not be pointed down. If you take a close look at the top of the battery you will notice a small plastic strip across the top. This hides the cell vents. If you charge the battery with the top facing down, the vents may leak some gell. Highly unlikely but possible.
Electrical current may not flow through any part of the metal frame of the robot....
<R51> All wiring and electrical devices shall be electrically isolated from the ROBOT frame; the
ROBOT frame must not be used to carry electrical current (this isolated ground arrangement
is necessary due to polarity reversals that occur under certain operating conditions such as
during motor direction reversals).
Yes inspectors do check. The common causes are improper insulation, improper mounting of custom circuit, mounting without insulation for sensors or pinched wires. On occassion, teams run wiring through robot frame and other team members will then unknowingly drill or machine the frame and damage the wire.
Unread 18-01-2008, 10:56
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
Re: Battery
Good advice from Al.
Just to clarify: robot inspectors will be using a checklist similar to the one currently available on the FIRST site. Electrical insulation and mechanical fastening of the battery will be checked per item 22 on that list, and electrical isolation will be checked per item 36.
Richard Wallace
since 2003
Battery Charger for long term battery care DougHogg Kit & Additional Hardware 0 08-02-2003 15:25
Battery archiver 2001 4 24-06-2002 01:10
battery archiver 2000 1 24-06-2002 00:26
battery archiver 2001 0 23-06-2002 22:51
Battery M.I. Technical Discussion 1 04-02-2002 17:13
