Go to Post Our team is using a video camera with frame-by-frame analysis to figure out all the characteristics of the foam ball. If the Boeing engineer says it's possible, I'm going to believe him. - sciencenerd [more]
Unread 16-01-2008, 12:34
Adama's Avatar
Adama Adama is offline
AKA: Matthew Eastman
FRC #2199 (Robo-Lions)
Adama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to all
Send a message via AIM to Adama
cad library
how do i bring in parts from the first cad library to my drawings?
Unread 16-01-2008, 13:34
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
Re: cad library
What do you mean by "to my drawings", are you refering to an assembly?
If so:
If your are using Autodesk Inventor, download and save the .INV file, then in the assembly toolbar, use the "place component" feature and browse for the file you saved, and click open, the selected part will then be placed in your assembly
Unread 16-01-2008, 15:27
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: cad library
If you use solidworks, download the .stp file from firstcadlibrary.
In solidworks, open the .stp file & save it as a solidworks part or assembly. Do not close the file.
In your robot CAD assembly, hit "Insert Component" and the part/assembly you downloaded will be in the list.
As far as I know in solidworks, you cannot merge two parts together and still call it a part; it's instead an assembly.
GitHub
Unread 16-01-2008, 16:36
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: cad library
I would add one more guidline when downloading parts from the FIRST CAD Library; put everything you download into a seperate folder for ease of finding stuff later on.
Also, a big thing with imported files with Solidoworks is that it loses all mating features when you bring in an .stp "assembly" btw.
What you can do (if you have a lot of time) is to go in the assembly file and mate all the .stp components together so that everything is now constrained..
This is easier on say the AndyMark toughbox transmission, than on the Omniwheels which are just pure nightmares to mate because of all the angled metal on the hub piece.
To get around this annoyance of having everything sperate when you move a piece of an assembly, a shortcut (re: way to cheat) is to put that unconstrained assembly of parts in another assembly file locked at the origin, & save that as a new (final) name assembly
Then pull that final assembly in to whetever you are working on. Everything will magically be fastened to each other as they originally came in.
We did this with the Omni wheels, and they now move as one entity in an assembly model at the next level up.
There actually is a way to do this, but I'm not too experienced with that command. One of the guys where I work showed me that command, and if anyone is interested in knowing it, PM me and I will ask him when he is in.
Unread 16-01-2008, 18:08
Gertlex's Avatar
Gertlex Gertlex is offline
Alumni and mentor
AKA: E Relson
FRC #1015 (Pi Hi Samurai)
Gertlex is on a distinguished road
Re: cad library
Solidworks can import any of the file types on the CAD library.
Has anyone else gotten at least one import error on every single file version of the FP Motor Gearbox?
A part file can contain multiple files and not be an assembly. There's an "insert part" feature. It is much trickier to do the mating, but is useful if you need to mimic the holes on a piece (i.e. a motor).
Unread 17-01-2008, 17:11
Adama's Avatar
Re: cad library
cool
im famaliar with using inventor (PLTW vet) although i was wondering how you find your parts after you downloaded the parts from the first cad library. It would seem that after you do this you just move them to a folder.
thanks every one
Unread 17-01-2008, 17:24
Sunshine's Avatar
Sunshine Sunshine is offline
Mr. S
FRC #2062 (C.O.R.E)
Sunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to behold
Re: cad library
Inventor likes all files in the same folder.
C.O.R.E. Community Of Robotic Engineers
2015 Wisconsin Regional Champs, Safety Award
2015 Midwest Regional Champs, Safety Award, Industrial Controls Award
2014 Midwest Regional Judges Award
2013 Lake Superior Champs
2012 World Championship Safety Award, World Finalist for the Autodesk Award
2011 Wisconsin Regional - Website Award 10,000 Lakes - Innovation in Control, Safety Award
2010 World Championship - Archimedes Semi-Finalists -World Finalist for the Autodesk Award
2010 10,000 Lakes Regional Champs, Entrepreneurship Award; Wisconsin Regional- Entrepreneurship Award, Safety Award
2009 WI Regional- Quality Award, Safety Award 10,000 Lakes - Safety Award, Motorola Quality Award, Animation Award
2008 World Championship Safety Award
2008 Wisconsin Regional Champs, Safety Award
2008 St. Louis Regional Entrepreneurship Award, Safety Award, Website Award
2007 Wisconsin Regional All-Star Rookie Award
Vex CAD Library gabrielse Inventor 7 29-03-2007 10:59
First Cad Library Macdaddy549 Inventor 1 02-12-2003 20:32
Cad Library Update archiver 2001 0 23-06-2002 23:36
CAD Library Updated ..... Ed Sparks General Forum 0 21-01-2002 18:19
Pneumatic CAD Library Ed Sparks General Forum 2 15-01-2002 22:16
