Go to Post ..the way we see it FIRST isn't about winning a robot contest, its about trying your best to complete a really really hard task in a really really short amount of time. - Stuart [more]
  #226   Spotlight this post!
Unread 16-01-2008, 11:03
Happy Birthday! Nathans Nathans is offline
AKA: Nathan
FRC #0004 (Element)
Nathans is an unknown quantity at this point
Send a message via AIM to Nathans
Re: New C18 3.0+ Compatible FRC Code
We're testing the new gyro code, but it overrides all of our commands and sets our pwm outs to 0. Once we put anything referencing the pwm outs we're using, it messes them up. We searched through the code, but we can't find anything that might be causing this. Has anyone else come across this problem?
  #227   Spotlight this post!
Unread 16-01-2008, 17:10
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Assuming you're referring to my code, what makes you think the gyro code is causing this? Can you use the "Find in files" search tool to find all instances of the PWM variable that's getting fragged?
-Kevin
Kevin Watson
http://kevin.org
  #228   Spotlight this post!
Unread 16-01-2008, 17:36
AKA: Nathan
FRC #0004 (Element)
-Kevin
We tried that on Monday. I don't have the results in front of me now, but they were all just definitions. I suspect it has something to do with the gyro code (as downloaded from this thread, not added in by us), as the plain C18 3.0 code doesn't cause this problem. We got this bug on 2 occasions, each time starting from scratch, adding only a few lines for straight joystick-to-PWM drive code, as well as removing the gyro calibration in one instance.
  #229   Spotlight this post!
Unread 16-01-2008, 18:27
Lafleur Lafleur is offline
AKA: Tom Lafleur
FRC #0812
Lafleur will become famous soon enoughLafleur will become famous soon enough
Serial Ports
Kevin:
Is there a hard limit at 128 bytes in the Serial Queue's??
RX_1_QUEUE_SIZE 128 // Must be a power of two (i.e.,8,16,32,64,128)
  #230   Spotlight this post!
Unread 16-01-2008, 19:02
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
(This may be a little bit of a tangent.)
I'd like to report to anyone who's interested that the C18 3.10 compiler works just fine under Wine (on Linux), after fixing one minor issue.
I had v 2.4 working under Wine. I ran the upgrade, and then things did not work. I don't remember the exact error, but it did not compile successfully. I copied my mcc18 directory from one machine (where I'd run the upgrade) to a different machine, and it worked fine on the new machine. I then copied my ~/.wine directory from the new machine back to the old machine, and the compiler worked fine.
If you plan on using v 3.10 under Wine, my recommendation is to do one of the following:
- Run the upgrade on a Windows machine, and then copy over the mcc18 directory to run it under Wine
- Make a backup of ~/.wine, then run the upgrade program under Wine, then restore ~/.wine.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
  #231   Spotlight this post!
Unread 16-01-2008, 20:44
FRC #2429
Re: Serial Ports
Originally Posted by Lafleur View Post
Kevin:
Unless you want to hack the linker script, I suspect the upper limit would be 256. Just out of curiosity, why do you need such a large buffer?
-Kevin
Kevin Watson
http://kevin.org
  #232   Spotlight this post!
Unread 16-01-2008, 20:51
FRC #2429
I can't think of anything in the gyro or ADC code that would cause this, but I'd be very interested in finding out if it's something knuckle-headed I'm doing in my code. Which compiler are you using and which robot controller are you using (i.e., what year is it from)? Can you zip up your code and send it to me?
-Kevin
Kevin Watson
http://kevin.org
  #233   Spotlight this post!
Unread 17-01-2008, 10:54
AKA: Tom Lafleur
FRC #0812
Re: Serial Ports
-Kevin
I don't, just wanting to know the limits of your code...
thanks...
  #234   Spotlight this post!
Unread 17-01-2008, 14:41
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Does it give anyone heartburn if I just release one build for each of the two compiler versions that has support for the ADC, gyro and encoders already built in? You'd be able to remove funtionality by commenting out a few #defines.
-Kevin
I vote for the "All in one" solution..... saves me from having to combine them (which I have a high probability of screwing up).
Phil.
Phil Malone
http://www.GEARSinc.org
  #235   Spotlight this post!
Unread 17-01-2008, 14:45
billbo911's Avatar
billbo911 billbo911 is online now
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Kevin,
This is just a thought and should be implemented by teams as they feel their needs require.
In the teleop.c file, you currently have the gyro bias calculation process happen in the Teleop function.
void Teleop(void)
	static unsigned int i = 0;
	static unsigned int j = 0;
	int temp_gyro_rate;
	long temp_gyro_angle;
	int temp_gyro_bias;
	i++;
	j++; // this will rollover every ~1000 seconds
	if(j == 10)
		printf("\rCalculating Gyro Bias...");
	if(j == 60)
		// start a gyro bias calculation
		Start_Gyro_Bias_Calc();
	if(j == 300)
		// terminate the gyro bias calculation
		Stop_Gyro_Bias_Calc();
		// reset the gyro heading angle
		Reset_Gyro_Angle();
		printf("Done\r");
	if(i >= 30 && j >= 300)
		temp_gyro_bias = Get_Gyro_Bias();
		temp_gyro_rate = Get_Gyro_Rate();
		temp_gyro_angle = Get_Gyro_Angle();
		printf(" Gyro Bias=%d\r\n", temp_gyro_bias);
		printf(" Gyro Rate=%d\r\n", temp_gyro_rate);
		printf("Gyro Angle=%d\r\n\r\n", (int)temp_gyro_angle);
		i = 0;
	Update_OI_LEDs();	// located in ifi_code.c
This may be fine in some instances, but in competition, the robot is powered up in disabled mode, then transitions into autonomous(Hybrid) then back to disabled and finally into teleop. The gyro bias would never be calculated until well after it may be needed.
Wouldn't it be better if this code were placed in the disabled.c file in the Disabled function. An additional flag could be set to prevent the bias calc process from running during any additional disabled periods.
  #236   Spotlight this post!
Unread 17-01-2008, 17:16
FRC #2429
I had a look at your code and it looks like the problem is your limit() function, which is returning a 16-bit integer when it should return an unsigned 8-bit byte. You also had semicolons immediatly after your if statments:
int limit(int value)
if(value >255);
  value =255;
if(value <0);
  value =0;  <== because of the added semicolon above, this statement will always execute and will always set the return value to zero.
return value;
Your code should probably look like this:
unsigned char limit(int value)
if(value >255);
value =255;
else if(value <0);
value =0;
return (unsigned char)value;
-Kevin
Kevin Watson
http://kevin.org
  #237   Spotlight this post!
Unread 17-01-2008, 17:22
FRC #2429
I've already made this change and provided a sample calibration routine in Disabled(). You're waiting because I'm deep in procrastination mode and haven't finished the first cut of the documentation yet <grin>.
-Kevin
Kevin Watson
http://kevin.org
  #238   Spotlight this post!
Unread 17-01-2008, 17:28
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
if(value >255);
value =255;
else if(value <0);
value =0;
Kevin, I think you forgot to remove the semicolons after the IFs in your reply. I think you meant it to be
  if(value > 255)
    value = 255;
  else if(value < 0)
    value = 0;
  #239   Spotlight this post!
Unread 17-01-2008, 17:40
AKA: Nathan
FRC #0004 (Element)
Thank you. I thought it was probably something stupid I did.
  #240   Spotlight this post!
Unread 17-01-2008, 18:00
FRC #2429
  if(value > 255)
    value = 255;
  else if(value < 0)
    value = 0;
Ahh, my devious little plan succeeded and I verified that at least one person is awake and actually reading the programming forum.
Dave, thanks for catching my gaff <grin>.
-Kevin
Kevin Watson
http://kevin.org
Does the camera code suits to all versions of MPLAB and C18? razer Programming 3 04-01-2007 14:50
Trying to follow C18 interrupt context code... dcbrown Programming 5 21-12-2006 09:01
Error w/ FRC code JamesBrown Programming 2 08-01-2005 16:17
Programming code Fix FRC Ferazel2001 Programming 6 08-02-2004 02:46
FRC default code hedgehogger Programming 2 21-01-2004 18:41
