Go to Post FIRST games are complex and rely on design and intellectual capability much more than the average sport. - Chris is me [more]
Unread 16-01-2008, 18:26
jasonpeinko jasonpeinko is offline
FRC #1087
jasonpeinko is an unknown quantity at this point
printf causes programs to not run
I was trying to setup a printf command in user routines fast, but when i upload it to the robot it gets stuck in program mode,
I used Jifi to upload it,
i also use mplab running under wine to compile.
Unread 16-01-2008, 18:54
psy_wombats's Avatar
psy_wombats psy_wombats is offline
AKA: A. King
FRC #0467 (Duct Tape Bandits)
psy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura about
Re: printf causes programs to not run
The fast loop, I believe, can't support the printf function, simply because it is a very fast loop. The printf takes a lot of time (relaying info through your serial) so the print is being called way too fast for it to finish, and causes the program error.
Should be able to fix by calling only by a timer interrupt, or when a loop count is divisible by fifty, (to call every fiftieth loop or something), or maybe use the slow loop?
Unread 16-01-2008, 19:02
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
I've done this successfully (when debugging shaft encoders), but wouldn't recommend it. It's very easy to crash things this way.
This is of course a much better solution.
Unread 16-01-2008, 19:03
gizzlyMIKE000 gizzlyMIKE000 is offline
FRC #1516
gizzlyMIKE000 is an unknown quantity at this point
how do i post a forum?
Unread 16-01-2008, 19:13
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Do you mean how do you post a reply? Well you just did, obviously. If you mean that you would like to start a new thread, then look for the appropriate topic and look for "start a new thread"
Unread 17-01-2008, 17:40
FRC #1087
i am confused on how to get this to work,
i have to it only is supost to show every 1000000 times the code runs.
Unread 17-01-2008, 18:54
FRC #1087
tomorrow i will try using the default prgoram with the controller to see if it work with printf, could the problem be that my computer is not being able to handle the printf when it recieves it back?
Presence of function causes auton to fail??? Kyveck Programming 13 16-02-2006 14:48
printf could not find definition Alex829 Programming 7 27-06-2005 10:04
printf statements do not display in autonomous mode PVC Pirates Programming 3 22-02-2005 15:41
printf isn't printf-ing. Help! Meandmyself Programming 14 15-02-2004 16:27
