Go to Post The best thing that could be said about 2015 was things could only go up from there. - Koko Ed [more]
Unread 17-01-2008, 20:18
robbrad robbrad is offline
FRC #1875 (Autonomato Autonomatons)
Team Role: Electrical
robbrad is an unknown quantity at this point
Custom IR Board
I have tried to build an IR remote from scratch befoe and had problems distinguishing a signal from ambient light. Does anybody have an idea on how the learning recievers take care of this? I would very much like to create a custom IR reciever board to take care of possible compatibility issues. If we are required to use common IR Com protocals for the device to recognise the data packets, I see a compatibility issue, especially if teams like to use the arrow keys on their remotes. I would like to design a board that uses a start byte, our team number, to rule out any possible "command overlap." Any filtering advice would be greatly appreciated. Thanks.
Custom Pneumatics - Control Board Selection? Erin Rapacki Electrical 3 03-04-2007 17:21
Lights in Joystick board or control board rcubes85 Control System 15 26-02-2005 23:40
Using Custom Inputs on the Controller Board schenkin Programming 10 27-01-2005 10:26
Perf Board = BS2-IC Carrier Board? indieFan Electrical 2 16-09-2004 08:28
custom titles shyra1353 CD Forum Support 7 28-12-2003 11:52
