Go to Post why does everyone think im so violent? - Kim Masi [more]
Unread 17-01-2008, 21:09
compwiz2008's Avatar
compwiz2008 compwiz2008 is offline
FRC #2139
compwiz2008 is an unknown quantity at this point
Question Joystick Output Values?
I'm having issues programming our team's drive motors, and I am programming them on asumptions. I am assuming that the following is true:
joystick left on x-axis = value of 126 to 0
joystick right on x-axis = value of 128 to 255
joystick down on y-axis = 126 to 0
joystick up on y-axis = 128 to 255
Can someone confirm that my assumptions are true, or that their false? Thanks in advance.
Unread 17-01-2008, 21:17
CyDrive's Avatar
CyDrive CyDrive is offline
FRC #1203 (pandemonium)
CyDrive is an unknown quantity at this point
Re: Joystick Output Values?
Yes this is correct though i think you are referring to the y when you say up and down.
Unread 17-01-2008, 21:19
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
Please specify. Do you mean the joysticks that come in the kit or a different joystick? I have a non-kit game port joystick and a saitek joystick that runs through a chiclet. They are the reverse of each other.
The best way to find out is to use the dashboard viewer and look at the values in the OI screen.
good luck
Steve
FRC #2139
Smile Re: Joystick Output Values?
yeah.. oops. thinking error... I will edit my original post...
Unread 17-01-2008, 21:29
CyDrive's Avatar
if you want just do a quick test
//This is assuming your controller is in port one of the OI
printf("p1_x= %d p1_y= %d \r",p1_x,p1_y);
Unread 17-01-2008, 22:40
FRC #2139
That is an excellent idea. I'm going to put the values onto the dashboardviewer, which will help with programming and also trimming the joystick.
To the post earlier: our team is using the standard kit joysticks.
Thanks for everyone's help!
Mixing Joystick Values for mecanum wheels Leav Programming 10 15-01-2006 14:51
Paint values capenga Programming 1 20-02-2005 13:25
Servo Values DanDon Motors 8 14-02-2005 15:49
Color Values WesleyBalmer Programming 3 15-01-2005 22:26
PWM Values... Ian W. Programming 4 17-03-2002 21:53
