Go to Post Before anyone accuses FIRST of being in the pocket of the sponsoring corporations, they might spend a minute and a half to actually apply some of that critical analytical ability that we are supposed to be demonstrating as educated engineers. - dlavery [more]
Unread 17-01-2008, 23:06
compwiz2008's Avatar
compwiz2008 compwiz2008 is offline
FRC #2139
compwiz2008 is an unknown quantity at this point
printf() syntax and parameters
I've been looking at using the printf() function to display joystick values, but I'm a little confused about the proper syntax and parameter usage to make the code work. I want to do the following:
Result text in IO:
X 126 Y 250 (Where 126 is the value of p1_x and 250 is the value of p1_y)
Could anyone enlighten me on this issue?
Unread 17-01-2008, 23:39
Re: printf() syntax and parameters
#include <stdio.h>
printf("X %d Y %d\n", p1_x, p1_y);
Unread 17-01-2008, 23:42
mormannoob's Avatar
mormannoob mormannoob is offline
President and Senior Programmer
AKA: Clinton
FRC #0498 (Cobra Commanders)
mormannoob is on a distinguished road
Result text in IO:
why dont you try ifi dashboard
http://www.ifirobotics.com/dashboard_viewer.shtml
you plug your OI to your computuer's serial port and it displays a lot of different inputs such as joysticks,buttons,etc
Why cant code work the first time
Wait I have to lead programmers thats like asking a kid who doesnt know how to ride a bike to lead a group of guys at the tour de france
Unread 18-01-2008, 13:57
gnormhurst's Avatar
gnormhurst gnormhurst is offline
Norm Hurst
AKA: gnorm
#0381 (The Tornadoes)
gnormhurst will become famous soon enoughgnormhurst will become famous soon enough
Maybe this is a holdover from the older version of printf(), but I've always been careful to cast (convert) any "char" types (one byte numbers) to "int" type (two byte numbers on the RC) like this:
printf( x value: %d,  y value: %d\n\r", (int)XAXIS, (int)YAXIS );
Otherwise you can get some huge, crazy values printing out.
Here's the quick story about printf() on any system:
printf takes a variable number of arguments. The first one must be there and it must be a string. It's called the "format string". That string can have anything in it. You put a '%d' each place where you want it to print a value. For each %d in the format string there must be a matching argument after the format string. They are matched up in the order the %d's appear in the format string.
You don't have to have any %d's. Then you are just printing a message that's always the same:
printf( "Starting autonomous...\n\r" );
Note the \n and \r. These make it go to a new line. The FRC printf() wants to see \r (I'm not clear on why) but in the rest of the world you would just use a \n ("newline"). Using both makes it work in all cases.
Use %d when you want to print an int type. There are other ones, like %f for "float" types, but if you avoid using floats on the robot controller (and you should avoid using floats) then you won't have a need for %f.
Trenton Tornadoes 381
2004 Philadelphia Regional Winners
2006 Xerox Creativity Award
My corner of the USPTO.
My favorite error message from gcc: main is usually a function
My favorite error message from Windows: There is not enough disk space available to delete this file.
Unread 18-01-2008, 18:36
Typecasting your arguments is a good practice to follow.
%f is not supported by this printf. %ld might be a better example.
You can find full excruciating details in the MPLAB_C18_Libraries document that came on the CBot CD in the Kit-of-Parts.
Syntax Error: externs, structs, and macros Astronouth7303 Programming 3 16-02-2005 15:39
Default Code and printf WilsonDJ00 Programming 2 22-01-2005 16:39
printf and newlines Jeff McCune Programming 5 21-02-2004 21:09
printf isn't printf-ing. Help! Meandmyself Programming 14 15-02-2004 16:27
