Go to Post Don't be too distracted by the shiny robots, and the games they play. Enjoy them, but keep your eyes on the real prize(s). - gblake [more]
Unread 17-01-2008, 23:11
baop858 baop858 is offline
FRC #0069 (Hyper)
baop858 will become famous soon enough
Send a message via AIM to baop858
Possiblity of using a few trig functions
Do you guys think there will be an problems if I used like 4 trig function on 28.6 ms loop? If I put the trig functions in the spin function functions would it work better? Would using a look up table for sin cos trig and arctan use up a lot of space?
Unread 17-01-2008, 23:36
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Possiblity of using a few trig functions
This won't be a problem if you aren't doing anything else time consuming.
-Kevin
Kevin Watson
http://kevin.org
Unread 17-01-2008, 23:53
comphappy comphappy is offline
AKA: Brennan Ashton
FRC #2605 (A2D_16)
comphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to behold
Send a message via AIM to comphappy
I would say that for most things actual trig functions are overkill, a look up table will good enough. As for space, it depends on how many values you need to calculate, and how many places you need them.
A2D Solving the Imaginary Error Function...
Unread 18-01-2008, 10:23
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Team 95 had done quite a few test bots using field coordinates, where every time through the loop we'd do calls to sin(), cos(), abs(), and atan2(), all while using shaft encoders and the gyro, and it's never been an issue. I wouldn't get carried away, however.
Unread 18-01-2008, 23:55
AKA: Brennan Ashton
FRC #2605 (A2D_16)
I would not expect abs to be take very many processors cycles, could be written as such,
int abs (int num)
if(num<0)
num=(-1)*num;
return(num);
Trig functions in C18 3.10 dmlawrence Programming 9 08-02-2008 09:33
Trig. Functions in EasyC miketwalker FIRST Tech Challenge 5 07-12-2006 23:27
speed of math.h trig functions? Jared Russell Programming 4 07-02-2006 07:13
Trig functions and type conversion kaszeta Programming 6 14-01-2006 23:34
Return of the Inverse Trig Functions Leo M Programming 3 24-01-2002 08:12
